Question about Krups Coffee Makers & Espresso Machines
Descaling indicator in Krups Grind and Brew Coffee Maker is still on after complying with all instructions from the manual.
Posted by Dorota Kus on
Ross Keen
  • Krups Master
  • 1,364 Answers
I'm not familiar with the model but I do know that you need to complete each and every step fully before the light goes out on the models I've worked on. Run through it again slowly before you worry yourself about a repair.
Posted on Oct 24, 2018
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Posted on Mar 15, 2007
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
Anonymous
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
Anonymous
SOURCE: cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Posted on Aug 03, 2009
Anonymous
  • 24 Answers
SOURCE: how do i clean my cuisinart grind and brew coffee
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Posted on Sep 10, 2009
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this...
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Sep 30, 2011 | Krups KM7000
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Why doesn't my Krups espresso maker produce crema when I brew espresso? Very little is produced and gets blasted away by the time it's don't brewing.
Crema is the goldish brown top that goes onto the top of the coffee once it is dispersed from the espresso tap and flows naturally as part of the coffee when coffee is made. Im not sure what you mean "blasted."
Perhaps you should flush through the machine with cold water a couple of times beforehand and also consider a descaling kit - check your manual or Krups if there is one for this model.
Crema isn't produced by any machine though.
Jul 25, 2009 | Krups XP 4050 Espresso Machine
I need an instruction manual for the cuisinart coffee maker DGB550BCU can any one help or tell me where to get one. Thanks
There is a free downloadable manual for the DGB550xxx series of Grind and Brew coffee makers.
Here's the link with the free downloadable manual
http://www.cuisinart.com/manuals/coffee_bar.html
Hppe you find this info helpful.Best regards!
Jul 02, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
FME4 won't brew; thinks there's no water
I believe that the description you made of the horizontal dashed lines indicates that the unit needs a descaling. If it also says "CALC" on the LCD display, then that probably means that calcium build-up needs to be removed. I am looking for my instruction manual because my machine is currently doing the same thing and in the past I've followed the instructions to descale it using a solution of water and vinegar. The weak acid from the vinegar removes the calcium deposits in the machine. Use distilled water and you won't have to descale it!
Jun 12, 2009 | Krups FME4 Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Coffee Makers & Espresso Machines Logo
148 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
