Microwave Ovens Logo
gary allison Posted on Oct 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp model smc1132cs disable beeper
How do I stop beeper
Deepak Mathur
Level 2:
Habit-Forming:
New Friend:
  • Expert 101 Answers
  • Posted on Mar 06, 2019
Deepak Mathur
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
101
Questions
0
Helped
50106
Points
188
The buzzer is responsible for beep,it is mounted on PCB assembly,either remove the same or cut the supply sourse to it.
How do i disable the beeper
Hello Friend, thank you for allowing me to assist you!
I see that your question is listed under Frigidaire microwave FFCE2238LW. Typically you will hear a series of beep once your food is done heating or defrosting has finished. For this purpose, the beeping signal cannot be deactivated and I show that the volume is not adjustable for your model. Most microwaves are preset to do this. Best regards! - Z
Turn off beeping sound on touchpad oster countertop
If the owner's manual does not mention this as an option, the only other option would be to disable the piezo beeper.
Here's a video showing you one way:
How can I silence the beeper on a Sharp Carousel microwave model R2A47?
Reset it, disconnect the power cord by 1 minute and try again.
If this does not resolve the problem. the problem is control board.
God bless you
How can I turn off the beeper on my microwave?
On some models, yes. Simply refer to your owner's manual to see if that feature is available on your model.
Otherwise, see this YouTube video.
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
1helpful
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
I have a Sharp Microwave Convection, Model # R-9H83
My daughter put the plate back in wet and the next thing I know it sparked and stopped working. Is it fried?
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
16helpful
4answers
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
