Question about Blaupunkt Televison & Video
Have you tried the remote to make sure it's switched on to digital or analogue?
Posted on Oct 23, 2018
Probably the problems started as the tuner board malfunction, replacing it should fix the problems.
Or, if you have the firmware of your TV, upgrade the firmware first
SOURCE: Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: [email protected]
Posted on Apr 19, 2008
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
SOURCE: Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Posted on Aug 22, 2009
SOURCE: tv bought for xmas gift. new tv showing no signal.
CRT tube tv must have Cable or Satalite signal.Must buy a Converter Box to convert to digital signal,for free air signal.
Posted on Jan 07, 2010
Dec 14, 2015 | Sharp Aquos Televison & Video
Sep 25, 2015 | Televison & Video
Jan 18, 2014 | Sagem Televison & Video
Jul 06, 2017 | LG 42-inch Flat Screen Led-lcd Tv - 1080p...
May 24, 2017 | LG Televison & Video
Feb 28, 2011 | Televison & Video
Nov 26, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
Sep 04, 2009 | Tvone LM-1501R 15" Flat Panel LCD Monitor
Jul 21, 2008 | Audio Players & Recorders
303 people viewed this question
