Question about RCA Audio Players & Recorders
When connected to the wall charger it will work, plugs up to a computer fine and charges. When connected to the wall, it plays songs and works perfectly. But it will not turn on if it is not plugged into the wall. I tried restarting my device, and even installed the newest firmware, but nothing is working. Does anyone know why it wont work if not on the charger? and, how to fix it? I searched around on a lot of different websites but nothing is working. ( i saw some suggestions on various topics to take the battery out, but i have the device taken apart and unsure of how to reach the battery. I don't believe that will solve the problem.) ((I also don't want to have to replace the battery, if at all possible.))
I found my dad's old mp3 player it works but when I plug it in after it says please wait and after that, it says FAT ERROR error reformat external media with sigmaTelfromatter. PLZ HELP ME
Posted on Jun 28, 2022
Do you use the same cable to charge your device on computer and wall socket? If not that might be your problem. It might show that it’s charging but actually there’s no power supplying to the battery. If it is the same cable try another USB socket your motherboard or driver could start causing problems so I would suggest to try the cable you use on the wall socket on another computer if possible.
Posted on Oct 21, 2018
SOURCE: My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Posted on Nov 11, 2007
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
Posted on Jun 04, 2008
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
SOURCE: Problems with USB port and charging mp3 player with MSI Wind U120
do the usb ports work at all, if not open the case and see if there is a loose wire.
Posted on Aug 21, 2009
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
Posted on Jan 03, 2010
