SOURCE: Finding full sz bed rails 4 my Simplicity Ellis Convertible Crib
i think i have a solution to your problem. I too have been looking for simplicity bed rails but in honey to convert to a full. I found sears.ca and they carry the rails in every color but there version of the ellis crib is called the sydney 4 in 1. It is the same exact crib so I am purchasing the rails myself. If they do not end up fitting then just send them back. Sometimes canada have the same things as us but they are named different I know I live 15 min away from the canadian border. Hope this helps.
SOURCE: I need bed rails for the simplicity ellis crib.
i have the same problem but i searched long and hard and found this wesite where you can purchase the conversion rails.
Simplicity Ellis Crib Conversion kit for Full size Bed
http://www.nybabystore.com/p-4994-simplicity-ellis-convertible-kit.aspx
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
[email protected]
Here are the instructions for your crib. Please review them
and see which parts you will need. We
accept Visa or Master Card. Parts are non returnable. Delivery is normally
7-10 business days. We do have replacement
parts for this crib. Please review the instructions and see what you will need.
J
Thank
you,
Cindy
Customer Service
Rep
Simmons Juvenile
Furniture
':Phone:
1-800-218-2741
':Phone:
1-920-779-4004
7:Fax:
1-920-779-4216
SOURCE: Need Ellis Cherry Crib Conversion Rails (or substitution) in US
Yes all i have a solution for the simplictity problem.
There is a company in Canada that has the conversion rails and other parts you are asking about. They do deliver to the US. There name is The Kiddies Store. The Ellis collection is called the Sydney.
Phone number is 1-800-755-4857
web site is http://www.tjskids.com/simplicity-sydney-4in1-convertible-crib-cherry-p-4226.html.
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
