Dishwashers Logo
M
Mike Posted on Oct 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire dishwasher will not start I have already replaced the door latch and control panel and it still will not start
Clifford McCawley
Level 2:
Habit-Forming:
New Friend:
  • Expert 43 Answers
  • Posted on Nov 20, 2018
Clifford McCawley
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
43
Questions
0
Helped
11294
Points
104
On our machine the door latch seems temperamental and we have to push the door closed quite hard. It will then start.
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 23, 2008
SOURCE: door panels for frigidaire dishwashers
sure its possible,stainless steel door 154538305 approx $100
Anonymous
  • 171 Answers
  • Posted on Sep 13, 2008
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Anonymous
  • Posted on Jun 12, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
kirchwey
  • 7 Answers
  • Posted on Nov 10, 2010
SOURCE: How do I replace the door latch on my dishwasher?
Don't try to bend anything! The latch mechanism in the door is probably broken. Open the door and remove the 11 torx screws holding the inner panel on. You will probably find broken plastic bits on the pathetically flimsy latch; mine failed after 4 years and I expect it to happen again.
If you do, see the link given in "I Have 3 problems with my dishwasher, my...",
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168615&diagram_id=1349844#d1349844 Unlatch the two switches and slide them off the old part and onto the new one, observing all the obvious precautions about not getting shocked and putting the switchess on correctly. Reassemble the door and latch with the screws.
Anonymous
  • 79 Answers
  • Posted on Feb 28, 2013
SOURCE: kenmore elite dishwasher stopped in middle of cycle
Here's your solution (free PDF) - Kenmore Elite Dishwasher Manual
I cant get my dishwasher to start
Defective Door Switch?The next thing that could be causing your dishwasher to not start could be the door switch. This door switch is also sometimes called a door lock or door interlock switch. This switch is a safety feature and makes it so the dishwasher will not run if the door is open. If your dishwasher won't start, then it is possible this switch is bad. This switch is located inside the door panel. To determine if the door switch is bad, remove the control panel, locate the door switch, and test it for continuity.
Blown Thermal Fuse?Another part in your dishwasher that could be causing it to not start could be the thermal fuse. This fuse is designed to blow if the dishwasher overheats. If this fuse blows, it will need to be removed and replaced to make your dishwasher work. Most dishwashers have the thermal fuse located in the control panel area. To determine if the thermal fuse is bad, remove the control panel, locate the fuse, and test it for continuity.
Broken Door Latch?The part that holds your dishwasher door shut is called a door latch. 99% of the time this latch is made from plastic. If this latch becomes broken or cracked, it will prevent your door from closing properly. To determine if your door latch is bad, inspect your dishwasher door and be sure the latch is not broken.
Defective Main Control Board?The control board in your dishwasher supplies power to all components. If your dishwasher won't start, this could mean that the board is bad. If you have tested and confirmed working all the other steps above, then the control board in your dishwasher is most likely bad and replacing it would be a smart option at this point.
How do I determine why my Frigidaire fdb510cfs0 will not start when turned on??
Hey friend, thank you for your post!
From what you have described your Frigidaire dishwasher, FDB510CFS0, will start operating. This could be a possible issue with your control panel or door latch. If you door is not latching properly then it is not sending the appropriate signals to your control panel. This could cause an error code to populate. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from it for roughly ten minutes. Hopefully this is helpful to some degree. -Matt
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
1helpful
FRIGIDAIRE dishwasher door won't latch
Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
2helpful
2answers
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
2helpful
Dishwasher won't start. Control panel lights come on when you press start/cancel, but it doesn;t run. I have checked door latch, any other ideas?
under the plastic door liner is the pcb timer and the white looking with 2 wires hooked to it needs replaced always unplug or shut off power to unit if working on it if you know how to use an ohm meter take a resistance reading if none replace the thermal fuse....
2helpful
Dishwasher will not start
Maytag quiet series 200, all lights are on the selector panel, when I press start nothing happens. I have already replaced the door latch control last week....Now What?
Apr 27, 2009 • Dishwashers
2answers
Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
43helpful
11answers
Frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
