Ovens Logo
PETERH Posted on Oct 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEFF STEAM OVEN FAULT CODE E5123 - Neff Ovens
Chris Huff
Level 3:
Top Expert:
  • Neff Master 6,289 Answers
  • Posted on Oct 20, 2018
Chris Huff
Neff Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017778
Points
74913
Https://www.northlondonappliancerepairs.co.uk/error-codes/neff-error-codes.html
Neff oven model B46FT64N0/35 stuck in descaling mode with error E5122 - How to get out of this?
Error E5121, E5122 or E5123: Is a problem with the pump or the water hose and indicate that either the pump or the water hose is blocked or calcified. ... The pump is particularly stressed during descaling and can cause a malfunction if it gets too hot.
Turn off the power for 2-3 hours and test again.
If it still does not work, the pump must be removed and replaced if necessary.
Nov 05, 2023 • Ovens
Neff Steam Oven error code E5123.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiwgLHn8vL-AhURAzQIHRE9BqIQFnoECBsQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29925510-neff_steam_over_error_code_e5123&usg=AOvVaw1yI-sjEM1vvRntCUJzF6u2
May 12, 2023 • Neff Ovens
Gaggenau EB 294/295 error code
1helpful
Cause of Neff Induction Hob Error d4?
I can only confirm that the is no D4 Error shown anywhere. If Neff, the maker can't tell you what the error is, then surely no-one can. Very poor show. I think I would be cutting my losses and go back to a traditional cooktop from a different maker and pursue a legal case against Neff. They should change their name to 'Naff'.
NEFF appliances are among the most durable and reliable kitchen devices on the UK market. But every once in a while, a NEFF appliance will throw an error code for you to deal with.
When a fault code is displayed on your NEFF appliance, it indicates a problem, but not what that problem is or what has caused it. An appliance fault code simply detects and indicates the nature of the issue and provides the general area where investigations need to be carried out.
Bear in mind that on many occasions, your NEFF appliance will be in need of professional repair from a certified electrician to get guaranteed results.
So, if :
  • You have a problem with your NEFF appliance
  • You want to know what a specific error code means
  • You want to trace and correct faults in your NEFF appliance
Then, read on.
NEFF appliances fault codes and their importance Your NEFF appliance will indicate an error code if it has a problem. This will be shown on the digital display and will be a single letter followed by one or two numbers. You can use this appliance error code to help identify where the problem is occurring. The most common appliance fault codes are related to defective oven elements, drainage issues on washing machines, and blocked pumps in dishwashers.
A detailed look at NEFF appliance error codes
NEFF induction hob error codes The most common faults of a NEFF induction hob are:
  • The hob not starting up;
  • The hob shutting off during cooking;
  • The hob flashing after finishing cooking;
  • The hob making a noise;
  • Food isn't cooking evenly.
NEFF induction hob error codes that may help you locate the source of the problem are shown here:
  • F1 - Tnsuitable cookware is being used, or there's no cookware in the zone;
  • F2/F02/F4/F04- Tour appliance hasn't cooled down completely;
  • F8/F08 - If your hob has been working on high power for a long time, the timeout will activate;
  • E9 - There's an internal fault with your appliance electronics.
Bear in mind that most of the issues will require a certifed induction hob engineer to complete the job and fix your NEFF appliance.
Feb 03, 2022 • Neff Ovens
1helpful
What does code 11 mean on a Miele steam oven mean?
I am assuming that its a DG6000 series Steam oven? The F11 fault is the steam gen drainage fault - drain valve defective or hose blocked
Mar 01, 2018 • Miele Ovens
I have a neff oven and the scre that holds the element in the top of the oven has gone so the element has dropped
the screw hole has corroded from steam and now the screw is to small there is a repair kit for this but a technician would have to repair it alternately you could screw in a slightly wider not longer screw but its only a temp fix.
May 14, 2016 • Neff Ovens
3helpful
Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
