Question about Pitney Bowes Office Equipment & Supplies
Just purchased a Pitney Bowes 3400 laser printer,scanner,copier,fax machine, I have no idea how to run it for printing computer info or any other function
Posted by Mel Mylrea on
Marvin
    Top Expert:
  • Pitney Bowes Master
  • 85,239 Answers
Go to the Pitney bowes website and find the operating manual.
Posted on Oct 19, 2018
ka4iup
  • 4,062 Answers
You can download a copy of the user manual from here.
Pitney Bowes 3400 PRINTER OPTION Manuals
You may want to contact Pitney Bowes customer support:
Pitney Bowes Support United States
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Posted on Mar 07, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: need to set a pitney bowes 9820 to print a fax confirmation
Function
74
set
12
set
set
stop.
Posted on Nov 20, 2008
Anonymous
  • 18 Answers
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Posted on Aug 24, 2009
Nike Merritt
  • 149 Answers
SOURCE: Pitney Bowes 1530 Memory Full
1. Press FEATURE
2. Press 9 9
3. Press * * * 1 (this is the service passcode)
4. PressYES
press 095
press yes
press stop to exit
Posted on Dec 21, 2009
Nike Merritt
  • 149 Answers
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Posted on Dec 24, 2009
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
I need to figure out how to load the paper in a Pitney Bowes fax machine, 9720
There is a drawer at the bottom of the machine, pull it open and put paper in in
Sep 28, 2009 | Pitney Bowes Office Equipment & Supplies
My Pitney Bowes 9820 fax machine says check printer service due. When I hit the help key it asks for a password which I entered 9820, but no other key after that seems to work
Service due and check printer may be two different problems
check printer may be a fuser or laser problem
service due may be a counter for a ozone filter that needs to be changed to make the EPA ha[[y. If you wait too long to reset the filter counter, it can go to a check printer and cease printing
To reset the counter, press function 99, yes,access code is ***1.yes
press 146, yes, then press 1 to reset, press yes. press stop to exit
Sep 14, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Mar 05, 2008 | Office Equipment & Supplies
71 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
