Question about Boston Acoustics Audio Players & Recorders
My Boston Acoustics Soundware Digital Cinema has no sound. The Remote and the Control Pod are good. The Control Pod receives the Remote signal, changes inputs and reacts to the volume knob.
Posted by Hector C Hernandez on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Posted on Dec 06, 2007
Anonymous
  • 23 Answers
SOURCE: computer speaker system need pinout of the 9 pin control output
Go to Newegg.com and purchase it.
Posted on Mar 17, 2008
Anonymous
  • 7 Answers
SOURCE: Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Posted on Feb 23, 2009
Anonymous
  • 7 Answers
SOURCE: Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Posted on Mar 06, 2009
issikiki
Naajiyah Auladin
  • 563 Answers
SOURCE: My remote control stopped operating my Boston
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Posted on Jan 26, 2010
My subwoofer just starting a clicking noise. what could it be?
You may have dislocated the voice coil. Repair shop may be needed.
Feb 19, 2015 | Boston Acoustics Audio Players & Recorders
How do i pair to a Boston Sound System
If your device requests a pairing code, enter the number 0 0 0 0.
Once paired, the Input Mode light will be solid blue for several seconds.
Sep 22, 2014 | Apple iPhone 5
Hi i have the Boston acoustics soundware xs 5.1 the sub stopped working the led shines red on stand bye and turns to green when the amp is switched on so i have taken it apart and found ZD3 has blown but...
ZD stands for zener diode and used for exact voltage regulation. Take out a known good one and go to a repair shop to replace. Make sure that when you re install, the striped (polarity) markings are in the same direction!
Mar 14, 2014 | Boston Acoustics SoundWare XS 5.1 Speaker...
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Feb 23, 2014 | Boston Acoustics TVee Model 26
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Replaced the ZD3 on the Boston Acoustics Soundware xs 5.1 subwoofer with a 18 Volt-1 Watt Zener part number 1n4746a. and works like brand new.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
Boston soundware 5.1 subwoofer is clicking on and off all the time
I dont have a solution, but Im having the same problem, and so is someone else:
http://www.avforums.com/forums/speakers/1205745-boston-acoustics-soundware-xs-5-1-review-6.html
Bad batch maybe? Lets get your input and maybe we'll get to the bottom of it.
Jul 10, 2011 | Boston Acoustics SoundWare XS 5.1 Speaker...
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
Cyber acoustic A3780 remote control schematic I receive the speakers in gift but the remote control is missing
replacement wired remote control pod that will work for the a3780 2.1 sound system
14.99 which includes US mail with visa or master card
Cyber Acoustics, LLC.
3109 NE 109th Ave
Vancouver, WA 98682
USA
(360) 823-4100
Mar 18, 2009 | Audio Players & Recorders
Onkyo SR605 Remote not working at all.
Dear Bzambo,
Sidlahora
Dec 06, 2007 | Onkyo TX-SR605 Receiver
315 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
