Question about Freezers
SOURCE: Igloo model ICE108. Why does the ice full light stay on when there is no ice in the basket?
Because the ice level sensor is stuck in the full or up position. As long as it is there, the ice maker is shut off and will make no ice.
Posted on Oct 27, 2015
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Posted on Apr 29, 2016
"The Igloo 100 series portable icemakers that are sold all over for about $100 have several minor issues. For ADD WATER light, there are 2 main ones. The water SENSOR is located at the top right of the unit. Remove the BACK cover with 6 screws on the bottom. Remove the TOP assy with 4 screws from inside the case. When the TOP is off, facing the unit from front, you see the small silver wire at the back right. Clean it AND the screw visible thru the hole in the plastic at the end of the sensor wire. The screw is the GROUND side of the sensor. This fixes many of the issues. But the SENSOR senses water FLOW, not water LEVEL. If the PUMP is not moving water, the sensor assumes you are OUT of water and turns on the ADD WATER light. The pump apparently burns out easily. Remove the PUMP wire connector from the CONTROL BOARD and check for continuity in the motor. Be sure your multimeter leads actually touch the connectors. The connection end is too small for most meters, so probe from the backside of the connector. If motor is good, check for 12vdc at the board side of the pump connector. Plug in, turn on. Should be 12vdc within 45 seconds. See, the water pump comes on first. When water is moving over the sensor, then the board will turn on the compressor and start freezing. "
Posted on Aug 27, 2018
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Apr 29, 2016 | Freezers
Apr 21, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Sep 07, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Oct 04, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Mar 20, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
370 people viewed this question
