Question about NEC DSX Systems NEC-780025 DTR-1HM-1 BLACK Single Line Ph Phone
My message light is still on after erasing the voicemail message. What can I do to turn the light off?
Posted by cdeslauriers on
Anonymous
    New Friend:
  • 11 Answers
Is the nec dsx telephone voicemail light red or green...?
if it's green, it's not the voicemail light, rather, it's the caller id missed call indicator. just look through your missed calls and it will go out... or if you have the admin software, go to class of service, station, and disable the caller-id alert lamp.
free download of admin software at our website http://www.nec-dsx.com
Posted on Jan 24, 2011
Rob C
  • 547 Answers
The term we used for this back when I worked for the phone company was a "stuck message waiting indicator" and the way to fix it was:
Call yourself and leave a message.
Hang up and wait 2 minutes (we used to say 5 minutes, but 2 is plenty)
Retreive/delete your voice mail message
That should clear the blinking light.
Posted on Aug 03, 2009
How do i delete my masseges
Are you asking about voicemail messages or text messages? Most phones allow you to erase voicemail by pressing the number 7 during or after the message. If you have a touch screen phone and want to erase text messages, try touching and holding your finger on the message for a few seconds...a delete button may pop up. 25254526-ipxh3zptubm5u5d1ogqxpt0r-2-0.png
Oct 24, 2014 | Cell Phones
Yellow light keeps blinking after you erase all messages.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 19, 2013 | Uniden DECT 6.0 Cordless Phone
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
Message light will not go off even having erased all messages on handset
You're subscribed to a voicemail system provided by your telephone company that records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Apr 03, 2011 | Uniden Cordless Phone
The voicemail light stays on and message on phone reads "Message for you" on display. Voicemail has been opened and says that you have no messages.
More than likely a co-worker used the "send message" feature on thier set. Under where it says "message for you" one of the soft keys should say MSG. Press the MSG soft key then the ERASE soft key. That will return your screen to normal.
Jan 19, 2011 | NorStar T7316E Corded Phone
Voicemail light flashing but no message
This can usually be fixed by calling the phone number that the voice mail indicator light is flashing on from a different phone number. Leave a voice mail message and then go into the voice mail and delete the message that you just left. The indicator light should then go out.
Sep 14, 2010 | Mitel 5212 IP Phone
The flashing message light will not go off
Do you have any voicemails that you have not erased? Have you tried deleting your recent call list or caller id? This is a message indicator. If you go into your menu, you can turn message indication off
Aug 25, 2010 | Uniden DECT 6.0 Cordless Telephone...
Turning off answering machine
Hi
you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
Hope that helps?
Apr 26, 2009 | O2 X2i Cellular Phone
NED Dterm Series E Message Light
I had this problem and finally found a number for Eschelon telecom (763 745 8000). This is what they had me do. Press the Speaker button and then enter 7732. This cleared the blinking light and inmail message. This happens when you receive an internal call and someone leaves you a message to call them back. Still can't figure out how to listen to the message. But this cleared the blinking light.
hope that helps.
Jul 01, 2008 | NEC Dterm DTP-2DT-1 Phone
Voicemail
This solution from castrunk fixed the problem for me.
http://www.fixya.com/support/t394785-model_4025
1. Press the "Message" button.
2. At "Call Back" press the button below "Yes"
3. The number that will be called back should be listed. Press the button below "Erase".
Your red blinking light should be gone now.
Feb 22, 2008 | Mitel Superset 4025 Corded Phone...
NEC DSX Systems NEC-780025 DTR-1HM-1 BLACK Single Line Ph Phone Logo
2,433 people viewed this question
Top NEC Lands Phones Experts
Zhareese
ray gallant
Andrew Taylor
Andrew Taylor
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
