Question about Razor Toys
A model number for razor scooter serial number 4002104312080039714 red
Posted by Bruce Winter on
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: Why is my razor e100 red electric scooter going so slow?
Your scooter is dying the slow death that all Razor scooter owners are suffering. See my related post on this. Anyway, here's the deal..
I HAVE THE SOLUTION!! No, it's not what you're going to want to hear, but I have it nonetheless. The cheapest and easiest way you're going to fix this issue is by firmly grabbing the scooter, hoisting it directly upwards, clearing the rim and depositing it into your nearest refuse container. This is junk at its finest, brought to you from the worst in value and service, the Razor Company.
I did a little investigation into this problem as I too experienced what everyone that owns a Razor scooter does; it works for about two months, then suddenly the "battery stops holding a charge". You can Google Razor scooter issues and get page after page of this happening, along with more pages of frustrated people learning Razor won't do anything about it. But I digress.. back to the facts..
I need not repeat what I've already posted with regard to the issues surrounding my scooter, purchased Dec. '08 as a Christmas gift and not ridden (midwest snow) until the last month or two tops. So as I posted previously, it stops working and I'm assuming it's the batteries. I call my local Batteries Plus store and they say they can help. Here's where it gets interesting.
I bring in the entire scooter and charger. Let me say that I found the charger included in with my scooter.. "interesting?".. as directly underneath the red/green lights there are Chinese characters instead of English words, thus I never had any idea what these lights indicated. That notwithstanding, the test the charger on the spot and tell me it's working and is (pay attention here) 41 volts of charge. This means nothing to me at the time. I learn that testing the batteries in the scooter will take a couple days and they say they'll call with the results.
Before leaving, one of the CSR's engages me in a conversation about his identical experience with the Razor scooter he got for his kids one year prior. The circumstances mirrored everyone elses: it worked for 2 months, stopped working, he checks the batteries, replaces them, still doesn't work, he pitches it. Hearing this isn't making me feel any better.
So the weekend passes and here on Monday I get the call from Steve at Batteries Plus. Here's what he finds: There are 2 batteries in the scooter; one is at 60% of its life (this after a mere month of use) and the other is overcharged and 'swollen'. How can this be I wonder? I followed the charging instructions provided with my scooter TO THE LETTER, never leaving it charged for an extended period, etc. Well the answer is simple- the batteries for this scooter are 24 VOLT BATTERIES being charged by a charger that is outputting 41 VOLTS!! ALMOST DOUBLE THE VOLTAGE! It's overcharging the batteries and frying them out.
Steve said he removed and replaced the batteries with 2 brand new fully charged 24 volt batteries and it still didn't work. He surmised the switch that activates the motor, which is run through the charging system, was fried during its last overcharging.
Ergo, the charger included with these scooters is frying the scooters out in a very short period of time. To replace the charger, both batteries, and the switch would be more expensive than just pitching it and buying another brand new one.
This issie is Razor's fault and they should be willing to fix the issues (cue laugh track here). Go to their site and be ready to laugh at yourself for even bothering. Here's what I found. First I click the 'service/repair' tab, then am directed to the 'Razor Service Center Locater' to find the nearest service center to me to have it repaired. I entered my zip code and it said 'Sorry, no results found'. I then try my city/state, and again get 'Sorry, no results found'. Not looking good.
I then begin reading their return policy. It has a warranty that's good for 90 days from the DATE OF PURCHASE. Naturally, in my case I bought it in Dec. but since there was snow on the ground it was useless until spring; I was screwed before it even was given it's first charge. However, for the regular customer they'll find that even so, it's right at about the 2nd/3rd month when this thing takes it's final ride and as such, and through no fault of your own, your're totally screwed.
There are enough complaints on this scooter on the web that at minimum contacting the BBB is in order, and might I suggest a potential class-action lawsuit? This scooter retails still at $149, and like most of you I don't have $149 to throw in the trash every couple of months only to go and repurchase another "disposable" scooter.
So there it is. Not only are the batteries being overcharged and shot, but collateral damage to the electrical system is being done which is frying the switch that engages the motor and other things. Have your charger checked at your local Battery Plus (no charge) and you'll see they are putting out a defective product, and based on several hits on the internet they are clearly aware of it and do not care.
Posted on May 11, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: when you put the scooter in to forwards and reverse the red light flashes 5 times then comes up error 5
hi , that is normally associate with a brake fault ? the freewheel lever ? making sure it 's in drive mode ... check all connections going to the brake from the controller.... two wires, it maybe a faulty micro-switch...
Regards
Rob
Posted on Aug 03, 2015
Jeff Bird
  • 1345 Answers
SOURCE: Where is the serial number found on a Invacare Aurgia10 4 wheel model Mobility Scooter.
Hi most scooter's have a sticker on the seat support shaft under the battery & motor cover cowling. Cheers
Posted on May 13, 2018
Want serial number
The serial number is normally on the frame, the numbers on any of the components will not be the correct serial number. Shoprider have stickers all over there scooters. check rear frame, seat post. It is an Easter Egg hunt sometimes with this manufacturer. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 25, 2016 | Shoprider Sprinter Deluxe Four Wheel...
Tga vita4 red light flashes5times then comes up error 5
hi , that s related to a brake fault, check connections and the micro-switch that is closed when you operate the free-wheel lever...
Make sure it 's in drive mode, you can push the scooter when i nthis mode...
Regards
Rob...
Aug 02, 2015 | Health & Beauty
How long does it take to charge Razor E100 Electric Scooter - Red
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
Sep 14, 2012 | Razor E100 Electric Scooter
Amigo Scooter; Model unknown; serial number AM1000728797
try this link http://myamigo.com/amigo-mobility-scooters-support/amigo-mobility-scooters-owners-manuals.html
Jul 09, 2012 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
Jan 29, 2011 | Razor 300001-SL Ground Force Go Kart
I need a key for a Merits Electric Scooter. On the seat post I found Merits *1030837*. Is this the model or serial number. How can I find the correct info and how do I get a key. Thank you, Dianne
Yes, the number on the seat post is a serial number for the scooter. Please call Merits in Florida at 1-800-963-7487 and ask them to send you a key. They may send you one for free or a nominal charge. If you need a key right away they will direct you to a local dealer who has one in stock. Hope this helps.
Dec 29, 2010 | NRS Merits S2351-ARMU Pioneer 1 Mini...
WHERE CAN I GET DEMINSIONS FOR A PRO RAZOR SCOOTER. IS THERE A WEBSITE I WANT TO MAKE ONE IM MY METALS CLASS. IM IN DRAFTING ONE SO I WANT TO GET THE DIMENSIONS AND PUT IT ON THE CAD SYSTEM.
Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
  • Razor Pro Model Scooter has a double stacked head clamp for extra head tube strength and the scooter is made from aircraft grade aluminum.
  • It has a full deck and 98mm urethane wheels equipped with ABEC-5 high speed bearings.
  • Razor Pro Model Scooter folds for easy storage and transport.
  • It can hold riders up to 220lbs.
  • Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
Sep 23, 2009 | Razor Pro Model Kick Scooter Fun Kid...
Toys Logo
768 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
