Whirlpool model mh1170xsy-0
Have you had trouble with the cooktop lights recently? The circuits for both lights and fan can be affected if so.
Does it happen when you are not cooking on the stovetop?
Your product support page is here, where you can get the owner's manual, installation instructions, parts list, etc. You can order Whirlpool parts from the Pros here.
If your controller needs repair, I do that. Details here.
SOURCE: New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
SOURCE: MIcrowave oven stopped heating - Whirlpool MH6150XMS
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Whirlpool Over the Range Microwave won't heat
Yes, I'm trying to help you. Sorry about all the questions, but it's part of diagnosis.
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
At this point, it seems pretty clear that the problem is in the high voltage section, most likely the magnetron, but possibly the high voltage diode or transformer..
Here are some links you or someone you know can use for test help to find the defective component, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
SOURCE: microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
