Question about Packard Bell Computers & Internet
I have a Easy Note M5 280DW and would like to know if I can upgrade the RAM?
    President:
  • 566 Answers
Standard Memory 256 (256MB x1 Removable) Maximum Memory 1 GB The standard memory of your system is 256 Mbytes and the maximum memory it supports is 1 Gbytes.
So you can either upgrade the RAM by adding 1 stick of 256 Mbytes (for a total of 512 MB) or buy two sticks of 512 Mbytes each (for a total and maximum memory of 1 Gbytes).
You are looking for PC2700 DDR Memory.
In any case, check the memory you have installed.
You can download a free utility like CPUZ that will give your information about your system, including the number of memory slots available and used and the memory (amount and type) installed: http://www.cpuid.com/download/cpuz/cpuz_152_setup.exe
Posted on Aug 03, 2009
6ya staff
SOURCE:
Maximum Supportable RAM size per slot in Dell N4010
go to crucial memory and download their memory scanner. it will tell you how much memory is installed and what the max is per slot on any computer. hope this helps
Jun 24, 2013 | Dell Inspiron N4010 Notebook
Need to know how to install additional ram
There is a little door under the laptop, with a couple screws.
If you open it, you will see the ram modules.
They are easy to remove and replace with additional (if empty slot available) or upgraded ram.
Aug 08, 2011 | ASUS Computers & Internet
Easynote w3910...what kind of memory do I need to ugrade
  • Your Packard Bell Easy Note maximum RAM capacity: 2GB
  • The Easy Note W3910 has 2 memory slots or sockets
  • This Easy Note module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR 333MHz, PC2700
  • The motherboard NON ECC DIMM type for your Easy Note W3910 is: SODIMM.
so your looking for 2x 1GB ddr 333mhz pc2700 memory chips.
Apr 01, 2011 | Computers & Internet
My presario 700 has a memory of 240mb, not quite sure, but can it be upgraded? up to what maximum ram?
hi,
yup your memory can still be upgraded up to its maximum supported RAM of 384 mb with a RAM technology SDRAM
note:
upgrading your RAM to that size doen't make major difference to its performance and you can't hardly notice it difference.
john
Jan 04, 2011 | Compaq Presario 700 470024-192 Notebook
I'm having problems upgrading the RAM in my Packard Bell Easy Note Argo C. I bought 2G of the exact same RAM that is already inside but it's not working. What shall I do?
Victoria,
It is not that you can add any amount pf RAM to ant PC/laptop. Each motherboard has the TAM quantity fixed and you cant exceed it. It may be less than that quantity or equal but not more. So must be the case with you.
Nov 15, 2010 | Computers & Internet
I want to upgrade my Advent 4489 Netbook to 1GB or 2 GB RAM. Is there a repair or upgrade manual I can get to help with this upgrade ?
Is easy, just need to open flap under Laptop, buy RAM, Remove Old, and clip in replacement. really not need manual. Just make sure you get correct RAM rest is easy.
Apr 04, 2010 | Computers & Internet
Is it easy to upgrade my own emachine so it will be faster and have a larger drive?
1st open the pc case and write the motherboard model.
then go to the motherboard company website, and check for the latest firware for your board, then check for spec for your board, memory, an so on... (Note the windows xp has limited hd size. and choose a 10000rpm hd disk and 16M buffer with a top graphic card for your board, and update the cpu), and your computer is tunned.
Dec 29, 2009 | Computers & Internet
Install memory upgrade
you need to find out what type of ram,and amount your motherboard takes (sd,ddr,ddr2,sod) and how many ram slots it has, the user manual of the mobo will tell you this information.if you dont have the manual search the net for it.
it is very easy physically on a desktop,you just push them in the slot ,taking note of the notches on the ram sticks,ensuring they lock down correctly,
note if you are using ddr2 you need to install in pairs to obtain the full speed of the ram,things can be a little more tricky on laptops as some are easy to get at, and others you need to remove the cover of the entire laptop.
good luck
Terry
Mar 09, 2008 | Computers & Internet
UPGRADATION OF RAM
Dear Sanjaykpaul.
This has to be checked with existing ram in your note book, The same type may be added to make it 512 MB or can be replaced with a new with Higher capacity. The speed should match with existing Ram Chip Module.
Best Regards
Rafique
Mar 03, 2008 | HP Compaq nx5000 Notebook
Computers & Internet Logo
211 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
