SOURCE: the message center shows incorrect outdoor
I would suspect that the connection to the outside temperature sensor is not good or the sensor itself is bad. Check the connection and clean and reattach as necessary. Otherwise replace the sensor. I think they're pretty reasonably priced.
The outside air temperature sensor for a 2000 Windstar is located under the front bumber on the passengers side. It is clearly visible if you lay down and look through the lower two air openings in the plastic bumper. It is the only electrical device in that area and it is made of black plastic.
SOURCE: I have a acurite wireless
In essence, you need to re handshake the units. There is a seek button on one or both that institues the process.
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
