Question about Beko Refrigerators
I have a BEKO GNE134620X fridge with a multifunction compartment, that only works correctly in fridge mode. When switched to freezer mode it will not cool below -6C. Does the main pcb need replacing?
Replaced multifunction air sensor which made no difference. The main fridge and freezer compartments operate correctly.
Posted by Peter Jacobsen on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Is anything blocking the sensor,if it does not cool below -6 and where are you checking temp it could be a refrigerant problem.Turn fridge off for 10 min and start again.
Posted on Oct 20, 2018
5 Related Answers
Anonymous
SOURCE: main food compartment not cooling
This just happened to mine (slightly different model number) and what it boiled down to was the air channels that bring the air from the freezer were frozen solid. You can remove the inside back panel of the freezer and get the ice out which is a temporary fix because more than likely, the defrost timer is bad and needs to be replaced. (It's frozen up because it's not properly defrosting) With mine, you could determine if the defroster itself is working by manually toggling it on and off. You said that the compressor is working so while it is running, manually toggle the freezer light on and off 5 times within 6 seconds (this is how it's done on my model) and you should hear the fan cut off. Make sure the drain pan is empty prior to doing this. Leave it alone for about 1 hour and you should see water in the drain pan. Just remember, this is a temporary fix but should at least allow you to keep your drinks cool until someone can come out!
Posted on Aug 29, 2007
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Robert Hirst
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
lenwest
Len West
  • 150 Answers
SOURCE: Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 16, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 08, 2009
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Beko ap930 no water geting to to ice tray
For me, this problem was because the tube was blocked with ice (the part of the tube inside the machine), which is why the tube popped off the back.
Try defrosting the freezer, or pushing hot water through the pipe with a syringe
Oct 28, 2009 | Beko 24 in. D3421F Free-standing...
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
My fidge wont cool down
Most likely a defrost problem..check the defrost thermostat, timer, heater, fan... if the fan in the freezer compartment running?? sometimes ice will form in the vents...check the easiest things first ..like the vents and drain tubes,,
Aug 20, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Beko Refrigerators Experts
gbob59
Marvin
Marvin
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
