Question about Video Cameras
Looking for objective variations for gr 9 Ems
Posted by Kairoon Dawood on
Crankshaft position sensor
Crankshaft Position Sensor Engine speed is a very important input to the Engine Management System (EMS). Crankshaft speed and position are the basis for many calculations made by the computer. Crankshaft position values are transmitted to the computer by pickup coils also known as Permanent Magnet (P/M) generators, hall-effect sensors or optical sensors. The Crankshaft Position Sensor (CKP) also known as engine speed sensor is located in close proximity to the crankshaft.
In addition, the EMS uses minute variations in the CKP sensor data to determine engine misfire. The EMS uses this information in conjunction with the camshaft position sensor to perform misfire diagnostics.
Related Symptoms No Start / Intermittent Start Condition - Can be caused by a faulty crankshaft position sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit.
NOTE: For procedures on the position sensors, please refer to Driveability and Emissions.
Removal & Installation To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section
  2. Raise and support the vehicle
  3. Remove or disconnect the following:
    • Air deflector
    • CKP sensor electrical connector
    • CKP sensor retaining bolt
    • CKP sensor
To Install:
  1. Lubricate the CKP sensor O-Ring with clean engine oil
  2. Install or connect the following:
    • CKP sensor and the retaining bolt
      1. Torque to: 89 lb-in. (10 Nm)
    • Oil filter adaptor
    • Air deflector
  3. Lower the vehicle to the ground.
  4. Operate the engine then inspect the CKP sensor for engine oil leaks.
  5. Perform the CKP System Variation Learn Procedure.
  6. Test drive the vehicle.
Jan 19, 2011 | 2002 Cadillac Sts
Compass direction wrong
Compass Calibration
Before calibrating the compass, drive the vehicle to an area that is magnetically clean or free of large metallic objects. Verify there are no magnetized objects on the inside or outside of the vehicle close to the mirror.
Start the engine.
Press and hold the switch for the compass, which may be depicted as COMP, COMPASS, or On/Off (w/UE1) depending on the type of mirror on the vehicle, until the letter "C" or "CAL" is displayed.
Drive the vehicle in circles at a speed of less than 8 km/h (5 mph) until the "C" or "CAL" is replaced by a proper vehicle heading. The calibration procedure is now complete.
Compass Magnetic Variation Adjustment
Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
Nov 09, 2010 | 2004 GMC Envoy
Built in electronic compass on 2004 GMC Envoy is giving the wrong directions
Try the following;
Compass Calibration
Start the engine.
Where is the cam sensor on a 2005 dodge neon sxt 2.0
Camshaft Position Sensor-On top of engine Operation The Engine Management System (EMS) uses the camshaft position sensor to manage sequential fuel injection and as part of misfire diagnosis. The EMS constantly monitors the number of pulses on the signal circuit. The EMS compares the number of camshaft sensor reference pulses and the number of crankshaft position sensor reference pulses received. If the EMS receives an incorrect number of pulses, Diagnostic Trouble Codes (DTCs) should be stored in the EMS. Some engine management systems will then default to multi-port or "gang-fire" injector operation. The camshaft position sensor signal is required to sequence the injector operation to the proper cylinder timing. If the camshaft position sensor or circuit is faulty, most engines will start. However, the EMS misfire diagnostic will likely be affected.
The following symptoms can be caused by an intermittent wiring connections or faulty signal to the EMS.
Related Symptoms
  • Extended crank time with a cold engine
  • Intermittent rough running
  • Unstable idle
  • Bucking
  • Hesitation
  • Stumble
  • Chuggle
  • Poor fuel economy
  • Stalling on acceleration
Aug 05, 2010 | 2005 Dodge Neon
High idle stalls at lights code for crank sensor
Crankshaft and Camshaft Position Sensors Camshaft Position Sensor Engine timing is determined from the relationship between the crankshaft and camshaft. This relationship is maintained by a timing chain or timing belt. The Engine Management System does not control engine timing but it does monitor the relative position and speed of these shafts by monitoring signals generated by sensors. The Engine Management System (EMS) uses signals generated by the camshaft position sensor to synchronize fuel injection to the valve sequence and for the on-board diagnostic procedure for misfire detection. The EMS energizes the injector at or near the time the intake valve opens. For misfire diagnosis, the EMS compares the number of camshaft sensor reference pulses and the number of crankshaft position sensor reference pulses received. If the EMS receives an incorrect number of pulses Diagnostic Trouble Codes (DTC’s) should be stored in the EMS.
If the camshaft position sensor or circuit is faulty most engines will start. Some engine management systems will then default to a pre-programmed injector firing sequence. All injectors may be energized simultaneously or all of the injectors on one bank may be energized at the same time. If the CMP data is required for misfire detection and reliable CMP data is not present misfire detection would probably be suspended.
Related Symptoms The following symptoms can be caused by an intermittent wiring connection or faulty signal to the EMS:
  • Unstable idle
  • Bucking
  • Hesitation
  • Stumble
  • Chuggle
  • Poor fuel economy
In addition the EMS uses minute variations in the CKP sensor data to determine engine misfire. The EMS uses this information in conjunction with the camshaft position sensor to perform misfire diagnostics.
Related Symptoms: No Start/Intermittent Start Condition – Can be caused by a faulty crankshaft position sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit
Jun 23, 2009 | 2004 Nissan Altima
Looking for sofeware for the jvc gr-D370u lost
Please go to the following link to download the drivers and manual for your JVC GR-D370.
http://camcorder.jvc.com/index.jsp
After you install the drivers you would be able to download and view them on your PC.
If you would like to touch the pictures or make major changes you should consider buying additional software.Good Luck!!!!!!
Jun 09, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Looking for a used/broken jvc GR-D290EKP camcorder
I have a jvc gr-d290ek digital camera which is not working due to cassette being stuck in the unit. Are you still looking for a used or broken camcorder of this kind?
Aug 09, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
165 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
