SOURCE: avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
SOURCE: magicolor 2300DL 17H fatal - labels stuck in printer
This happened to me last week. A label (or part of it) has adhered to the belt inside the printer. It's an easy fix. Turn off printer and open the side door. Remove waste toner bottle. Lift blue handle in direction of arrow to 11 o'clock position to release belt unit. Carefully remove OPC drum by pressing and pulling handle as shown by little graphic (try not to leave this drum in lighted area and don't touch green drum with fingers). Next, remove two chrome thumbscrews (may have to use slotted screwdriver) on either side of belt unit, then pull out belt unit and inspect to find stuck label. You can rotate belt easily. I removed stuck label and then cleaned glue residue with Elmer's Sticky Out ( a citrus product with no solvents) and a soft cloth. Clean thoroughly and replace belt unit, replaced thumbscrews, OPC drum, and finally, the Waste Toner bottle. Close door, turn on printer and test.
Neil
SOURCE: Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
SOURCE: Printer Jam - when i put a sheet of Avery labels, printer jams
I had the same problem and was able to get around it by changing my paper setting within the Printer Properties page from "Plain Paper" to "Inkjet Paper." Hope this helps!
