Question about Green Cameras
SOURCE: Minolta G500
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Posted on Aug 24, 2007
SOURCE: the phase 4 led on my gigabyte ep43-ud3l ights up
hi..the mother is need a complete the supply on board pin..then double cheek the memory..thanks..Good Luck...^_^
Posted on May 13, 2009
SOURCE: dell latatude D630 is docked/battery flashing 4 red 1 green
4 orange and 1 green can mean a battery malfunction, or it could be an indication that the battery is about to reach the end of its life cycle. When a battery is built, it has a planned expectancy. a date code is stamped in the electronics of the battery pack. as that date code is reached, the indicator lights on the computer let you know the battery (even if its working fine) is considered obsolete and needs to be replaced soon.
Posted on Nov 05, 2009
SOURCE: Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical
deflection stopped. Possible causes: +- 15V is not supplied. (D board),
IC8003 is faulty. (A board) Symptoms of the problem: TV has entered
standby state after horizontal raster, Vertical deflection pulse is
stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
SOURCE: picture won't come on. light flashes green
Hi:
This model was notorious for fan failure. The most common failure was the lamp temp fan. Its use to keep the lamp a constant temp. Also if one of the fans fail the unit will not start, This model is also known for Ballast failure also. The ballast is use to light the lamp. The best thing you can do is have a service technician come out and diagnostic the set for a minium fee.
Posted on Nov 09, 2010
Testimonial: "Very helpful in narrowing down severity of the problem."
