Question about Avanti Refrigerators
AVANTI SHP1701B MINI FRIDGE DOES NOT COOL . ANY ANSWERS ?
Posted by Gilbert A Moreno on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Does the compressor start have a close listen could be going out on thermal overload,possible start relay faulty.
Posted on Oct 20, 2018
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Avanti RM440W mini fridge not cooling.
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check.
1.) Door Not Sealing Tightly - I addressed this problem by raising the front end of the unit to assist the door in remaining tightly closed.
2.) Bad Thermostat - This is a long white tube about 1/8" in diameter mounted on the liner wall.
3.) Freezer Compartment Iced Up - You only have one cooling source and that is your freezer compartment. If the compartment is full of ice and frost you will not get good cooling.
4.) Refrigerant Leakage - Most Probable - The freezer section is made of formed very thin plate. The raised contours are also very thin. Your owners manual advises not to use hard steel tool to defrost. All to often, my customers use hammers and screw drivers to defrost and nick the contours. Run you hand across the cooling plate. If you feel a oily substance, then you have a refrigerant leak. If you have a service contract, it is less expensive to replace the unit than repair the seal system.
Dec 28, 2014 | Avanti Refrigerators
My Avanti is not getting cold.
I have an Avanti mini refrig. thermoelectric having trouble getting it to cool or cold it is a model EC15W-2
Jan 06, 2010 | Avanti EC15W-2 Compact Refrigerator
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Fridge temp high
freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Aug 31, 2007 | Avanti 310SST Compact Refrigerator
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Refrigerators Logo
392 people viewed this question
Top Avanti Refrigerators Experts
Bill Boyd
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
