SOURCE: remote codes
Check out this website...
http://remotefinder.rca.com/default.aspx?site=rca
You will need to check the model number typed in the battery cover of your remote to be sure.
SOURCE: A/V Mode
I HAVE A 19 inch tv Orion MY DVD manual says I need a input remote so the unit can work
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
SOURCE: I have lost the remote to my sanyo DP32746 32 inch
just go to sanyo service center to buy a new remote control, to fix your problem
