Question about Jabra Radio Communications
Every couple of minutes the jabra speaker says power on, then power off, then connected, then not connected.
Posted by Brenda Crisp on
HOW TO CHANGE LANGUAGE ON JABRA MINI BLUETOOTH
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Oct 12, 2016 | Jabra Solemate Mini Portable Bluetooth...
I need instructions for paring with my phone
Make sure your phone is on discoverable bluetooth on, power on your device, it will be auto on, then your phone may give you a code to punch in or you may just connect. Pretty simple, I found it sometimes asks you to put the code in if you are some distance from your device, ignore it, it should just take a minute and will connect auto.
Apr 21, 2015 | Jabra Cruiser 2 Bluetooth In-Car...
Major static with bluetooth speaker
With your "new" computer, you get up to 90 days of "free" technical support, via telephone, from Dell. Telephone them.
Feb 23, 2014 | Jabra Solemate Speaker System - Wireless...
Jabra How To Connect to my PC
Hello
Are you prompted to enter a Bluetooth pairing code? The pairing code for the Jabra Solemate is 0000.
Try disabling the Bluetooth on the Windows 8.1 device and then re-enable it and then try the pairing again.
Oct 26, 2013 | Computers & Internet
Can you sync a Jabra BT2080 to a Jabra A120?
Hi Bobby Smith1,
Im afraid that is not possible.
the reason is that the Jabra BT2080 is only ment to connect to a mobile device which is used for calls.
and the Jabra A120s is only ment to be plugged into a speaker device whilst connected to a mobile phone.
in fact both the Jabras work like a Normal headset, thus two are not able to be connected. only through a mobile device.
i hope this helps, good luck!
Mar 15, 2011 | Audio Players & Recorders
I just found an old (about a year and a half old) Jabra bluetooth freehands device. However, every time I try to pair it with my phone, it can't find the device. the model of the device is GNM-0TE3. my...
I just hooked it up to my iphone, What you need to do is set your phone to bluetooth searching then hold the top power button down on the jabra til the light is flashing, Then hold the jabra next to the phone and hold down the center button on the jabra for a couple of minutes and your phone'll pick it up, hope this helps, if it dont email me at [email protected] and we'll figure something else out.
Aug 16, 2010 | Nokia Cell Phones
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
English instruction manual
you need to charge the head-set fully and then.... disconect it from power supply. hold down the call button until a continus light appears. and then flip out the speaker tusk.... then search for the device on your phone a couple of times.... if you dont find your headset then your phone is not compatible with the head-set....
Nov 28, 2007 | Jabra BT8010 Wireless Headset
Radio Communications Logo
60 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Mosaub Al Masri
Mosaub Al Masri
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
