SOURCE: I have problem in my garage door. I have manual
Does this opener have intellicode opn it? if so it can teach itself the code. What excactly are you wanting, are you needing to find out what the code is on the opener to program the remote? Is your opener a Genie model also? I also need the model of the remote to find the coding info on this.
This is from Genie themselfs. ( Remotes manufactured after 1996 should work with your Intellicode® opener. Pre-1996 remotes use fixed-code sequencing and are not supported by Genie® Intellicode® technology. If you are unsure about when your controller was manufactured, contact us, your local Genie® retailer or your local Genie® ProTM dealer.)
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
