Posted on Oct 18, 2018
SOURCE: ALCK-486 time setting
In regular mode press "M" (mode) 3 times.
set the second first by pressing the "D" (date) button to reset 0, then press "S" (set) to confirm. The minute will start flashing. Press "D" (date) to adjust then "S" (set) to confirm.Repeat the same procedure to set the hour. Press "M" (mode) button to confirm all the adjustment and return to Regular mode.
Posted on Nov 05, 2017
SOURCE: auto-set clock radio with digital
Hi masbarn - I could try and walk you through it but I've always believed it's better if someone has the manual with the pictures. The link below is for the T311. It supposedly is the same manual you need. If not let me know. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Jeff
Posted on Jul 31, 2008
SOURCE: don't know how to set
It's very easy to do. First, make sure the 2 little slider switches on the far right hand side that turn the alarms on and off, are in the "down" off position.
On that clock, just to the right of the large snooze button there are 5 small square buttons. Time, Fast, Slow, Alarm set 1, Alarm set 2.
Depending on which alarm you want to set, hold down that button and simultaneously push either the "fast" or "slow" button to the left of it. The numbers will move forward fast or slow depending on which button you're pressing. Keep an eye on the upper left corner to determine when you've gone past 12 noon - as the indicator for PM will light up.
Keep holding down the 2 buttons until you get to the time you want. Then immediately release the fast/slow button. Your time is set. Do the same for alarm 2 if needed. When finished, flip up the switch for the alarm you want to activate, and you're good to go. Piece of cake! It took me a few minutes to figure it out; but after doing it one time...it's easy. Hope that helps.
I love this old Sunbeam clock. Only problem is the alarm is not very loud and there's no way to raise the volume - short of connecting wires to the speaker and using a powered speaker. Cheers!
Posted on Oct 30, 2011
SOURCE: What size button battery do I need for my ALCK-487 mini clock?
There is a picture of the battery L1131 TS Button cell.
Posted on Oct 17, 2016
