Question about Harley Davidson Lands Phones
Need parts for harley davidson floor lamp phone # please?
Posted by Cindy Gustafson on
5 Related Answers
Anonymous
  • 216 Answers
SOURCE: 1998 harley davidson softail custom primary cover bolt pattern
Are u asking for the torque sequence for the outer primary cover ?
Posted on Nov 21, 2008
jimmy nutron
jimmy nutron
  • 132 Answers
SOURCE: what type of motor oil used in 1994 harley davidson 883
harley recomends that you use their oil but i would be carefull because it is a cynthetic now if you were using regular oil what that will do is clean all the old build up out of the motor this can be bad because after time there are pin hole leaks that occure but the build up stops it from leaking but if you use cynthetic you cant go back to regular oil it will gum up on you and ruen your motor so you got to find out what has been put in it. but use a 10-30
Posted on Jun 05, 2009
wd4ity
wd4ity
  • 4565 Answers
SOURCE: Adjusting timing on Harley Davidson 1976 sportster
The advance timing should be 35° before Top Dead Center. This is how you find out which mark this is.
Get the rear wheel of the bike off the ground, remove the spark plugs, shift the bike into fourth gear, and remove the timing plug from the left engine case.
Now, take an ordinary PLASTIC DRINKING STRAW and insert it into the front spark plug hole. Do not use anything else or you stand a chance of it breaking and then you'll have to pull the head to get it out. The plastic straw will bend but not break.
Bump the rear wheel in the direction that it turns while riding down the road until the piston pushes the straw all the way up and just barely starts going back down. Look into the timing hole. You should see a timing mark. This is the Top Dead Center mark. Now, bump the rear wheel BACKWARDS until you see another mark. This should be the ADVANCED TIMING MARK. The piston should 7/16" down from top dead center.
On this model Sportster the timing is advanced by a mechanical advance mechanism. These units are notorious for wearing out and not contolling the timing very well. You must remove the breaker plate to inspect this mechanism. Mark the position of the plate before you remove it. If the pins and holes in the flyweights are worn, replace the unit. Replace it with a good needle bearing unit. Replace the points and reset the gap at 0.018 - 0.020".
Posted on Sep 24, 2009
wd4ity
wd4ity
  • 4565 Answers
SOURCE: clutch cable broke at handle lever on 1979 harley davidson sporst
To change the clutch cable on you '79 Sporty, you'll have to take the outer primary cover off. To do this, you'll have to drain the oil from the primary, take the left side foot peg off, and loosen the primary chain adjuster on the bottom side of the primary. Loosen the locknut and use an allen wrench or hex key to screw the adjuster bolt downward.
If you need to know anything else, drop me a line at [email protected]
Then, remove the large "plug" towards the rear of the cover. Inside, you'll see something that looks like a nut but with no threads in it held in by a small spring. This the the lock nut, remove it. Below it is what looks like another nut with a slotted adjuster bolt sticking out. Remover the bolts from around the primary cover and break it loose from the engine. While turning the adjuster screw at the rear of the cover inward, remove the cover.
The cable connects to the cluch release mechanism. By turning the "link" downwards, you can disconnect it from the mechanism. Notice which way the "link" in attached to the release mechanism. Take the "link" off the end of the clutch cable.
Break the lock nut loose at the threaded cable adjuster on the outside of the case and screw the adjuster all the way out of the primary cover. Disconnect the cable at the handlebar lever and your cable is out.
Reinstall the new cable in the reverse order. When replacing the outer primary cover, make sure you use a new gasket on the cover as well as on the foot peg boss. The "foot peg boss gasket" is very important. You'll see an aluminum boss with a threaded rod sticking out of it that holds your left foot peg on. There is a round gasket that goes over this threaded rod and seals against the boss. If you leave this off, your bike will leak oil around this threaded rod when your foot peg goes on. Make sure you specifically ask for the "foot peg boss gasket" when you buy the new primary gasket. It's just a round gasket a bit larger than a quarter.
As you put the primary cover back on, there is a spring on the primary chain adjuster. Part of the spring is in the primary cover and the other part is in the engine. You'll see how it goes in. There is a large stud in that area that the outer primary cover slides up on. Adjust the tension on the primary chain by removing the "plug" at the top of the primary cover. You want 3/4" to 7/8" up and down play in the chain with the engine cold.
On the adjuster, as you're installing the outer cover, turn the ajuster screw back into the clutch release mechanism by turning the screw backwards. Once you have the outer primary cover completely installed, you must adjust the release mechanism. Adjust the screw inwards until you feel a resistance, then back the screw off about a 1/4 to 1/2 turn, insert the "lock nut" and spring, and install the "plug". Then, using the cable adjuster on the outside of the cover, adjust the cable. Add oil.
Posted on Oct 26, 2009
Anonymous
SOURCE: KNG America Harley Davidson Motorcycle Lamp Repair.
Big tip 'o' the hat to harleyds96 for giving me the impetus to get after it and tear the lamp down and sort it out. You'll need a precision Phillips #1 screw driver to remove the 8 screws. You'll have to pry the 4 little rubber pads off that double as screw hiders
Once you've carefully separated the bottom plate from the rest of the pedestal, you'll see that you need an extra set of hands to hold the plate, amber glow ring, and the main lamp body with, while you fight with the little fuse box in the center of the lamp.
They all have to be held, because the speaker wire runs through the amber ring to the bottom pad, and can't be unplugged, 'cuz it's soldered. No spade connectors, nah, that'd be too easy - and complicated. They'd like to make it so much easier to toss out another $80 for a replacement, 'cuz you stupidly lost the receipt!
So now that you've got everything separated, you discover that there's another two screws holding the ends of the fuse box to the main body of the lamp. Yes, they must be taken out too, so's you can properly fight with the four little clasps holding the fuse box together!
If you can get it popped open without ripping wires from their solder connection, you're a neurosurgeon! I lucked out, 'cuz I did the operation whilst sitting at the computer desk, so the bottom two pieces could rest on it, without ripping the speaker wires off of the speaker, while at the same time, the main body of the lamp was resting in my lap.
Now that you've succeeded in getting the box open, you'll see that you have that little fuse there, that the Harley lady mentioned above found. It's stamped - 1A/250 V, which, I suppose, would mean it could be plugged in down undah, where they use 240 volts.
So I'm going to see if I can find a 2A/250V fuse somewhere, and if that's too hot for it - TOUGH! I'll have a Harley Davidson plastic patty melt! vonster.vaughn
Posted on Oct 10, 2010
Gear lube for a 1967 Harley Davidson M50 sport
Hi, Rich for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected] Good luck and have a wonderful day.
Gear lube for 1967 Harley Davidson M50 sport Google Search
Harley Davidson 50 Service Manual
Sunnymead Cycles Aermacchi Harley Davidson Manuals Catalogs
Harley Davidson Sprint Original Owner Manuals Moto Italia $20
Instant Repair Help over the Phone to speak to me personally $4
Aug 17, 2018 | Harley Davidson Motorcycles
1979 Harley Davidson FXEF starter motor housing bolt size
Hi, Kathy for this scenario you will need your service manual, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
1979 Harley Davidson FXEF starter motor housing bolt size Google Search
https://www.carlsalter.com/mcpdf/Harley-davidson-1978-80%20FL_FX%20Service%20manual.pdf
https://www.carlsalter.com/mcpdf/Harley-Davidson-1971-84%20FX%20Models%20Parts%20Catalog.pdf
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm free owners manual
Aug 03, 2018 | Harley Davidson Motorcycles
2003 Harley Davidson FXD Dyna Super Glide how to remove the seat
Hi, Tim for this scenario you will need your service manual, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Harley Davidson Maintenance Tips Softail Dyna Battery Seat Install
Dyna seat removal Harley Davidson Forums
Harley Davidson 2003 Dyna Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/harley-davidson-dyna-glide-owners-manuals
Jul 29, 2018 | 2003 Harley Davidson FXD Dyna Super Glide
2008 Harley Davidson Sportster 1200 Custom fog lights
Hi, Randy 9 volt lights are not going to work properly in a 12 volt system for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Motorcycle Fog Light Assemblies for Harley Davidson Sportster 1200 eBay
2008 Harley Sportster Service Manual zip
https://www.zipware.org/
2008 Harley Davidson Sportster 1200 Custom Owner Manual
Jul 22, 2018 | 2008 Harley Davidson Sportster 1200...
Harley Davidson SX 125 cylinder head nut torque spec
Hi, Ross for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Harley Davidson SX 125 Manuals
https://www.mrcycleparts.com/parts/harleydavidson/sx125
Aermacchi Harley Davidson Sprint Parts
Instant Repair Help over the Phone to me personally for a mere $4
Jul 19, 2018 | Harley Davidson Motorcycles
Transformer is bad in the harley Davidson lamp
Hi, Rebecca did you mean Voltage Regulator? I still need the year and model of your Harley for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at [email protected] Good luck and have a nice day. Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jul 15, 2016 | Harley Davidson Motorcycles
1994 Harley Davidson FXSTC Softail Custom how to adjust rear drive belt tension
Hi, Fred for this scenario you will need your service manual, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Harley Davidson Belt Adjustment
84 99 Harley Softail Servicer Manual pdf
Instant Repair Help over the Phone speak with me personally $4
Aug 06, 2014 | 2007 Harley Davidson FXSTC Softail Custom
2010 Harley Davidson FLSTF Softail Fat Boy bungee nuts
Hi, Peter for more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected] Good luck and have a wonderful day.
https://www.bowkerlifestyle.co.uk/harley-davidson/harley-davidson-parts/harley-davidson-security-and-storage/chrome-bungee-nuts-1750933323
2010 Harley Softail Service Manual pdf
2010 Harley Davidson Fat Boy Owner Manual
Dec 16, 2017 | 2010 Harley Davidson FLSTF Softail Fat Boy
Lands Phones Logo
79 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
Steve F
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
