Question about Panasonic TH-42PX60U Television
TV doesn't work
No picture or sound, only makes buzzing noise
my tv fell and broke with a few large cracks from the inside of the screen. theres no picture or sound except for a buzzing sound. what should i do? please help.
  • Anonymous Jan 07, 2008
    where can i buy the spare panels from?
    thank you in advance
  • Anonymous Mar 31, 2014
    Sony TV has sound but no pictures except lines going diagonally across the screen
Anonymous
  • 4 Answers
If the TV cost to much to repair, would you be willing to sell it for parts? My front glass screen has got a chip in it. Cant see paying 500 just to have a new one installed.
Thanks
Posted on May 20, 2008
Anonymous
    Problem Solver:
  • 4 Answers
To my opinion, if it costs like $997.45 to get a new panel, I 'd rather buy a new TV.
The Brand new Plasma TV panasonic 42 TH-42PX77U only cost $1,200.00 at the Fry electronic store.
So, you should reconsider your decision on the back panel...
Posted on Jan 08, 2008
Christopher Davis
  • 47 Answers
The fact that the television fell means that the warranty is voided. That is considered physical damage. If you did not mount it, try contacting whoever did and see what options you have, if any.
Posted on Jan 06, 2008
Robert Johnson
    Sergeant:
  • 395 Answers
You broke the panel, that is not covered by warranty a panel replacement would cost you the same or more than the cost of the set.
Posted on Jan 05, 2008
  • Robert Johnson Jan 08, 2008
    Panel replacement requires a tech to replace because purchasing panels even out of warranty requires authorization, there is no place that sells used or "spare" panels. cost of this panel is $997.45 plus shipping (truck frieght). panels should not be replaced in home and must be replaced in shop. these panels are fragile and can not be flexed (requires 2 people for replacement). shop labor prices vary from $200.00 to $300.00 depending on the shop.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I turn the tv on and there is a constant buzzing sound what is it?
Hello
If the picture is correct in all resepect, and only a buzzing sound only comes from its inside circuit, it will be due to a loose core fittings, on any one or two ferrite cored transformers inside the power supply sytem. There are transformeres of small and large types, both in power supply and other boards. We have to find out which transformer makes this buzz sound during working. For this, you have to open your TV, and power it ON, and listen the the sound carefully, and detect the transformer which makes this noise. After finding the exact one, this loose core contact can be fixed with the help of Super Glue or similar fast acting adhesive. Just put three or four drops of adhesive in between the core will rectify your problem.
If there is no picture at all and a buzzing sound like this is heard from your TV, the inside circuit has some short in it and has to be detected and rectified. OK>
May 01, 2011 | Polaroid FLM-323B Television
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
I changed the bulb in my tv and it was working for a few days. Now I get audio but there is a wierd electrical clicking noise which made me think the new bulb broke but I still have a green light on the...
In this case there are two possibilities of what part is the one causing the issue, it coul be a ballast because of the clicking sound that caused the tv to shut off, and that buzzin sound is for your color wheel that it might not be working anymore, discountdashmerchantdotcom free troubleshoot
Jul 24, 2009 | Mitsubishi WD-65733 65" HDTV
Magnavox 50MF231D/37 Plasma tv
The plasma panel in most cases exceeds the cost of replacing the TV. There is also the issue that they tend to use different versions and makes of panels in these sets. Some panels are made by Samsung and some are made by LG. I would start shopping for a replacement TV at this point.
Feb 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Has a sonud, but no picture
i posted this exact same problem and some wiz said that i broke the panel. now the warranty is voided and the only way to fix it is to purchase another panel which could cost the same if not more than the original, so your probably better off buying a new hdtv than trying to fix this one.
Jan 05, 2008 | Panasonic TH-42PX60U Television
Buzzing sound coming from TV
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Mar 14, 2007 | Harsper HP-4200VPM Television
Panasonic TH-42PX60U Television Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
