Question about Westinghouse Refrigerators
Hi, is the Westinghouse fridge model WTM420WB-R7 a frost fre model. Thanks
Posted by Jenny wake on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Yes all modern fridges are frost free.They introduced the heater element automatic defrost system.which is controlled by the defroster timer motor,in anyones lingo more things to go wrong,hope this helps.
Posted on Oct 20, 2018
5 Related Answers
Anonymous
SOURCE: Fridge timer location
THREE DIFFERENT LOCATIONS FOR DEFROST TIMERS ON
MOST REFRIGERATORS.
1 BEHIND THE REFRIGERATOR IN THE COMPRESSOR COMPARTMENT.
2 BEHIND THE TOE PLATE LOCATED ON THE FRONT BOTTOM OF THE REFRIGERATOR.
3 IN THE FRESH FOOD SECTION WITH THE CONTROLS
ON SOME NEWER ELECTRONIC MODELS, THE DEFROST IS
PART OF THE ELECTRONIC CONTROL LOCATED BEHIND A PANEL ON THE BACK OF THE UNIT.
Posted on Apr 01, 2008
Anonymous
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
Anonymous
  • 5 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
Anonymous
SOURCE: Westinghouse Fridge and separate Freezer - What Watts?
internet daownlod maneger serial no need
Posted on Mar 15, 2010
Anonymous
  • 126 Answers
SOURCE: Westinghouse Silhouette Frige 522 frost free is
UNPLUGGED FOR 24 HOURS AND LET IT TOTALLY DEFROST.
Posted on Apr 24, 2010
I AM AFTER A MANUAL FOR MY WESTINGHOUSE 2 DOOR FROST FREE 517 LITRES REFRIDGERATOR MODEL RJ522V-R THANKS JULIE
Check the westinghouse web site. Many manufacturers publish user manuals for some products on their company websites..
Nov 13, 2015 | Westinghouse Refrigerators
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Westinghouse rs662v cooling element frosting up.
Write down your model number search for a new thermostat online YouTube has videos on how to replace them yourself.
Apr 14, 2013 | Westinghouse Refrigerators
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
Apr 24, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Sanyo Mini Fridge
Same problem - When defrosting and moving away frost had a spray come from the left side of fridge. Can I repair - if a leak and how to add more freon?
May 03, 2008 | Sanyo SR-4910M Compact Refrigerator
Refrigerators Logo
59 people viewed this question
Top Westinghouse Refrigerators Experts
Vincent G
Vincent G
Sheldon Dedek
john h
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
