Question about Motorola Televison & Video
I have a handheld vingcard motorola terminal with Persona LockLink- Version 3.1. Whenever I try to program a lock I get an error "Cannot open communication port COM4:"
We just used the terminal an hour ago to program another door and it worked fine. No power surges or software changes. Any advice to fix the problem?
Posted by Jordan Bailey on
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
Posted on May 15, 2007
Anonymous
SOURCE: Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Posted on Nov 22, 2007
Anonymous
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Posted on Dec 07, 2008
Anonymous
SOURCE: programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Posted on Jul 10, 2009
SOURCE: I have one 3COM 4200
Are you using any firewall. If so, try disabling it and try to communicate the switch once again. I am sure it might be an issue with the security software.
Thanks and regards,
Anil.B.R
Posted on Oct 16, 2010
Lock the laser on a MC9590
Hi!
You could install "DataWedge", there you can configure the functionality of the laser.
By "lock" I hope you mean "Always on" in which case you can configure that:
1. Install DataWedge on the device (If not done so already)
2. Open DataWedge on the device (Control Panel)
3. Select "Advanced Config"
4. Profiles
5. Profile 0
6. Input
7. Scanner
8. Select your scan engine, in my case "Blok buster"
9. Reader Params
10. Aim Type
11. Select "Continuous Read".
12. Exit
Let me know if you have any troubles!
Cheers.
Callum
Mc55 won't open program
Contact Motorola Solutions.
Get Support or Zebra Technologies. Support Downloads
Mark
Motorola Mobility Support
Need to reassemble at vingcard 2100 lockset
I can help you out. Please contact me from the "contact us" page on my website www.ElectronicLockSmith.com. I need to get a little more info from you about the version and then I can provide with you some help. You can also call me Monday-Friday. Thanks, Ken Croston Jr. 407 814 8974
They are probably in a format that the pda can not handle.
2answers
Not working properly
your mobile have old version are low version of java thats why heavy java apps or new java files can not run in ur fone.
plz dont forget to rate
CRC ERROR COMING WHILE OPENING FOLDER LOCK 3.6
Okay, what happens when the program is used is that it changes the folder types, so they can not be accessed.The most common prom associates with those types of software is corruption, and you are now a victim of it. There is unfortunately nothing you can do about it, you can try to purchase a software and run a scan, but the likelihood is that your files are now gone for good. Also the company no longer supports this version of folder lock, so getting support out of them is going to be difficult. But, I might try to contact them, and see what they say, but there is nothing you can do.
Sorry,
Ryan Frame
Creative Energy Associates Technical Center
Blackberry pearl
the only thing that you can do for this error message is to reload the operating system on the blackberry. You have to have the blackberry desktop manager installed on your computer first. Once the program is installed then perform the following
To run Application Loader on your computer, follow these steps:
  1. Connect the handheld to the computer (insert the handheld in the cradle or connect directly by USB cable).
  2. Open the BlackBerry Desktop Manager.
    • Note: Click Start, Programs, BlackBerry, Desktop Manager.
  3. Verify that a pop-up window appears when the handheld is recognized.
  4. Click Application Loader if the pop-up window does not appear.
  5. Click Update Now.
    • Note: (This option only appears if new device software is available).
  6. Click Next to open the 'Handheld Application Selection' window.
    • Each application lists (along with its file size) with a check box and an 'Action' item.
  7. Review the following information about items that appear in the 'Action' column:
    • Install: Appears when an application is not present on the handheld.
      • The application loads on the handheld.
    • Update: Appears when the application version on the handheld is older than the version available with the Application Loader tool.
      • The most recent version of the application loads on the handheld.
    • None: Appears when the application version on the handheld is the same as the version available with the Application Loader tool.
      • The application does not change on the handheld.
    • Downgrade: Appears when the application version on the handheld is more recent than the version available with the Application Loader tool.
      • The older version of the application loads on the handheld.
    • Remove: Appears when a check box is cleared beside an application and that application was already present on the handheld.
      • The application is removed from the handheld.
    • Note: For more information on a particular application, select the application, then click Details. The handheld’s standard system software is also listed in the 'Handheld Application Selection' window. The software must be loaded on the handheld. The check box cannot be cleared.
  8. Click Next.< been have selections all>
    • The 'Application Data Backup' window appears.
  9. Verify that the first option is selected by default.
    • Note: This option automatically backs up handheld applications and data. Data restores after the handheld software reloads.
  10. Click Next.
  11. Click Finish when asummary window appears.
    • The actions that occur during the loading process appear.
  12. Verify that the handheld resets.
    • Note: This process may take a few minutes.
  13. Click Close to return to the Desktop Manager.
  14. Verify that the Application Loader indicates whether or not the process is successful.
    • Note: If the loading process is not successful, verify that the handheld is connected to computer properly. Repeat the above procedure if there was a connection error.
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
