Question about Lite On Computers & Internet
What cd rw driver will work in place of lite on LH-52R1P for my crosley composer CR 247
Posted by Bill Smith on
5 Related Answers
doubledge
Laird Page
  • 13 Answers
SOURCE: Lite On LH-18A1P DVD RW
Copywrited DVD Movies require that an MPEG software DVD Decoder be installed on your system. Windows doesn't include any because of their Anti-Trust violations and court issues.
(not to be confused with other media players, and DVD players that are included with DVD Movies, such as HOTLLAMA, and Interactive - you still need a DECODER. This is a throwback to the early days of PC DVD ROM's that required a HARDWARE MPEG DVD DECODER be installed, usually in a PCI slot, and connected to your video card through the VESA expansion connector. Nowadays, the hardware is built into the DVD unit, but it still requires a software decoder to operate).
Every DVD ROM or Burner comes with one...usually "Cyberlink PowerDVD", and now Nero's included one in their bundled OEM package.
Any version of any one of these will unlock the "DVD Movie" features for all media player installed on your PC.
[oops, almost forgot, you need Nero 7 or better for Vista. Any Cyberlink should work for you].
If you don't have one, try borrowing one from anyone who's got one. You can also go the P2P route, and download one, if you're so inclined.
Good luck, and I hope that fixes your problem!
Posted on Jan 08, 2008
James Mcphee
  • 43 Answers
SOURCE: My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Posted on Feb 17, 2008
Anonymous
I have two LITE-ON DVD DRW LH-18A1P on drive (E:) and drive (F:) It has gone from everything working great to not being able to burn a DVD. When placing a DVD into either (E:) or (F:) it shows up in my Window's Explorer as a CD drive.... Only allowing me to burn a CD in these drives.... Can play past burnt DVD's though in both both drives.... hve tried a couple of different brand disc, LG and TDK and get the same message appears 'to please insert a dics', need help I do!!! lcs2
Running Window's XP
DVDMy LITE-ON DVD DRW LH-18A1P
Posted on Oct 09, 2008
Anonymous
SOURCE: My drive is not reading dvd's
i have LG DVd writer combo drive. it reads cd but does not read dvd.
Posted on Mar 19, 2009
Anonymous
  • 56 Answers
SOURCE: Optiarc CD-RW CRX880A Reads CD/DVD, FAILS to write intermittently
To my knowledge, that is a firmware issue. Go to http://www.sony-optiarc.us/en/support-service/downloads/fw_cd-writer-dv-series3.htm and click the last link, which is the firmware download.zip for your updated firmware. Install that, and try again. If you have any problems, repost and i can try helping again.
Sean Huffstickler
Posted on Jun 03, 2009
Lite on dvdrw lh 20a1l wont play cds
Hmmmm.... Most new DVD drives have the problem.
Clean the cd with water and shampoo if it is having too much scratch. Try after drying. Is that helping?
NO? Is that CD working in other drives?
YES? Then you better replace the drive if it is under warranty.
Aug 10, 2010 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Downloaded windows 7 os and lost the drivers for my lite-on lh 20a1p! how to fix this problem?
If windows 7 does not pick up the drivers on its own then i suggest going onto the website to find them, they normally have driver updates there that should work fine.
Jun 19, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Won't read dvd or cd
Hi , visit www.compuvest.com you can find dvd-rw driver on sale.
May 14, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Drivers
Yes, there is no problem with that.
Oct 28, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Running Window's XP
Oct 09, 2007 | Lite On LH-18A1P DVD RW Dual Layer Burner
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
