Question about Optics
SOURCE: Stereo in 2001 Mustang Bullit
you probley have two cds jamed in there if you can here the motor trying to eject the cd and bogging out. or if you can here the eject motor running smoth and nothing coming out the gears are broke. you will have to pull the deck out and dismantel if you want the cd back.
Posted on Jul 13, 2009
SOURCE: My 10 year old 11-87 is sporatically not feeding
Sounds like she needs a good cleaning and a light oiling.
Posted on Feb 27, 2010
SOURCE: i have a ithaca model 49 lever action single shot
there is a lever under the barrel and it is probably worn beyond function or broken off all you need to do is disassemble the gun and replace it. ( get yourself some good brass punches)
Posted on Feb 28, 2010
Testimonial: "sounds good ,i will try it.thanks"
SOURCE: model 70 270 win will not eject spent shells
The ejector pin becomes flattened with sharp edges... it shaves brass, the brass helps stick the pin which is also penned out and a bit larger now. I took mine out and honed it so that it did not shave brass and would slide easily in the hole.... Make sure your spring is back in before you try the pin (You want something to push it back out). Most important... don't let the pin and spring get away from you. You can look on a chambered and ejected cartridge to see exactly where the bras is being shaved from. In my case it was the very back, outer flange, indicating the ejector pin.
Good luck ... hint... really use your eyes
Posted on Nov 02, 2012
Apr 02, 2018 | Retail Supplies
Nov 23, 2016 | The Optics
Sep 18, 2015 | Optics
Apr 21, 2014 | Mossberg Optics
Dec 06, 2013 | Remington Model 552 BDL DLX Speedmaster,...
Apr 07, 2013 | Optics
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
Aug 20, 2011 | Remington Powder Actuated To Power Load...
Feb 26, 2010 | Water Sport
Jul 13, 2009 | 2002 Ford Mustang
174 people viewed this question
