Question about Seagate Computers & Internet
SOURCE: How do I format a Seagate 500 to work on a Mac?
I bought one of the Seagate FreeAgent 500 devices yesterday and followed the instructions on the back of the box: plug it in; let the Mac recognize it; go to the Disk Utility function (found in Applications > Utilities); select the Erase tab and check the box to re-format the FreeAgent to Mac OS Extended (Journaled) and choose a name for it. Then proceed with the re-formatting. It took only a few minutes but as soon as it was done, Time Machine (Leopard) kicked in and asked if I wanted it as my backup drive. I said yes, and away it went. Hope this helps. By NewbieMacUserSept2007
Posted on Dec 29, 2007
SOURCE: Need to backup data on vaio vgn-t170p
yeah, do not format the disk and install operating system to other partition.
Posted on Dec 02, 2008
SOURCE: Hdd password frozen on laptop
if you download the sata drivers from the toshiba website for your specific laptop and then extract them and get nlite ( www.nliteos.com and slipstream the drivers into the xp disc you can then re install xp and it should allow you to boot.
As for the hard drive frozen password that should be in the bios on the hard drive that you set it for so it should remember it
if not you may have to contact toshiba and they should have a back door password that they can produce once you give them the asset tag ( serial number of the laptop ) and once you enter that it should resolve the hard drive frozen issue.
Had a hard drive frozen at a school once and had to call dell ( as it was a dell laptop obviously ) and gave them the serial number and they created a back door password for me - jobs a good one :D
Posted on Apr 29, 2009
SOURCE: Restoring files after using the Backup utility.
1. Plug in the USB drive that contains the data.
2. On the XMB go to Settings then System Settings
3. Go to Back Up Utility like before but
4. Choose Restore rather than Back Up
5. The PS3 does the rest
You can have the PS3 delete the data file from the USB drive by choosing Delete Backup Data.
Posted on Sep 18, 2009
Testimonial: "Thank you so much! it worked!"
SOURCE: I have a 3.5
You maybe able to retrieve data from this hard drive by connecting it to an USB hard drive adapter. Then plug this adapter into a working computer's USB port. If the hard drive is OK then this computer will see the adapter as an external hard drive and you can open the folders and files and copy them to the computer's hard drive or to a USB flash drive.
Posted on Jan 22, 2010
