On the homepage, you should see a link to Service & Support near the top of the page. Click or tap on that link.
On the Service & Support page, you should see a link to Lost Combinations. Click or tap on that link.
On the Lost Combinations FAQs page,if your lock is an "old style" dial combination lock, first open the first question: Q: I've forgotten the combination to my standard dial combination lock. Follow the on-screen directions.
Look through the list of other FAQs and open any which are relevant to you and read the information provided.
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock.
With the Combination
Step 1
Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
Step 2
Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
Step 3
Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination
Step 1
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2
Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3
Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination
Step 1
Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Step 2
Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Step 3
Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Step 4
Roll the dials until you have your new combination.
Step 5
Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals! www.alibaba.com$0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now! www.hostgator.com/1PennyRooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now! www.airconditionings.cnDownload Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now! www.facebook.comby Taboola Sponsored Links Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft RecipesSee Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
Do not open a lock that does not belong to you. It is against the law.
ABOUT THE AUTHOR
Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
I just unlocked a 1534 4-digit lock I couldn't open for 2 years. I found the info online. Use a flat blade to spread the wheels apart slightly and look for the red mark on each wheel. There were only three metal tabs on each wheel on mine so if this is the same on yours and you can't find the tab with the red mark, worst case senario would be to record each number shown at the mark when one of the tabs is lined up. It will take 3^x turns max to find the combination without locating the red marks. For 4 wheels, that is 3x3x3x3 or 81 possible combinations. For 5 wheels, it would be 3x3x3x3x3 or 243 possible combinations.
If you can find all but one red mark, line them up with the mark on the lock and go through all digits on the one you couldn't find. Shouldn't take too long. I tried to unlock mine by brute force (every possible combination of 10000 choices) and ran out of steam less than half-way through. That was with only 4 wheels and 10 digits each.
Your later generation Apple iPod can be locked to protect your personal data from anyone else's eyes. There are a variety of ways to unlock it depending on your access to the combination, the primary computer linked with the iPod, or neither. Difficulty: Easy Instructions
Unlock with the Combination
Remember the 4-digit combination you used to set the screen lock.
Enter the exact combination. If the combination is correct, the iPod unlocks and displays the screen you were on before you locked it.
The numbers on the screen flash red if you enter the code incorrectly. Unlock with the Primary Computer
Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
Open iTunes and sync the iPod as normal.
Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it. Unlock by Restoring
Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Check the MasterLock web site to see if they still offer to provide for forgotten combinations. Some years ago I got a combination for a standard rotary dial lock by providing the usual identification information plus a photo of the lock showing its serial number.
