Question about Optics
Brownie 2000 semi 12 gauge with a bush barrel, great shape 10 shells fired, what would it sell for?
Posted by Joe Mathieson on
5 Related Answers
Anonymous
  • 117 Answers
SOURCE: 12 gauge shotgun shell converted to metric (ex. 12 gauge + 20mm)
A ordinary 2 3/4 inch 12 guage shell equates to a European 70 mm. a 3 inch Magnum is a 76 mm.
Goof Luck.
Posted on Mar 27, 2009
Jerry Parmanand
  • 449 Answers
SOURCE: 92 lumina, 3.1, 4spd auto. Gas gauge operating
The float in the tank is not working properly or it could me a problem with the gauge.
Posted on Oct 19, 2009
Testimonial: "That is what I thought as well. Do you know how to access the float and pump on this vehicle? Can you access it from the trunk? Thanks!"
agent91
Ned White
  • 2100 Answers
SOURCE: I have a feed problem with my Remington 1100.
You have a shell stop that is either bent or worn, I think there are 2 in there, would have to look. Go to Gunparts.com for the view and order parts, might find them on ebean. Hope th is helps.
Posted on Mar 14, 2010
raysaw
  • 267 Answers
SOURCE: we are trying to figure out when are great
Check out this post at shotgun world...
http://www.shotgunworld.com/bbs/viewtopic.php?t=21196
Posted on Mar 25, 2010
Adam vliet
SOURCE: I have a Fabarm 12 Gauge Ducks Unlimited Shotgun that is brand new. I need a manual to see if there is a way to keep the chamber open and also how to eject the shells not fired.
To keep the bolt open you have to push the loading port toward the rear of the gun. you will hear a click if you've done it correctly. Now when you pull the bolt back it will stay in place. Hope this helps!
Posted on Feb 12, 2012
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
Want to find rifle barrel for a H&R model 176
Won't work, even though it's a 10ga., it won't take the pressures of a rifle caliber and the firing pin is too big. H&R will re-barrel a shotgun to another shotgun gauge or a handgun caliber. They will re-barrel a rifle to a shotgun gauge, a handgun caliber or another rifle caliber. You have to send it back to them to be fitted, they won't just sell you the barrel.
Dec 18, 2014 | Optics
Winchester 1400 ser#L2538861
I'm sorry, but there are no published serial number year of manufacture information for the Model 1400. It was first introduced in 1964 and was offered in 12, 16 or 20 gauge with 26", 28" or 30" vent rib barrels. This Model was discontinued in 1981.
The new Model 1400 was introduced in 1989, was chambered for 12 or 20 gauge with either a 22" or 28" vent rib barrel.
The Model 1400 Ranger is a utility grade gun in 12 or 20 gauge, a 28" vent rib barrel, 24" slug barrel with rifle sights or a two barrel set. It was introduced in 1983.
The Model 1400 Quail Unlimited was introduced in 1993. It has a compact engraved receiver with a 26" vent rib barrel and checkered walnut stock.
The Model 1400 Ranger Deer Combo is a 12 gauge only with a 22" smooth barrel and a 28"vent rib with 3 win chokes.
Values for all are : excellent-$350, very good-$300, good-$250, fair-$200, poor-$125
Add 35% for the Plastic stock on the first model and 20% for 2 barrel sets.
Sorry I couldn't give you the year. The only way to get it is a factory letter from Winchester which will cost about $100.
I hope this information has helped you. If so then would you leave some good feedback for me.
Thanks,
Marty
Aug 17, 2014 | Sport & Outdoor - Others
I have a early model 12 remington pump. 22 short, long and long rifle, the shells load into the barrel fine but are very tight and hard to get out after fired. why is this?
Sounds like it's actually made for 22 shorts, only, and the long and long rifle are extending past the chamber and wedging in the slightly smaller bore beyond the chamber after firing. (the casing expands slightly...)
Feb 16, 2014 | Sport & Outdoor - Others
Wenchester 1300 pump shoot one time then jams
This is the cars and trucks section, but I will try to help. Make sure your barrel is fully turned into the receiver. Check for cleaning pads jammed into a moving part. Make sure your shell length is correct for the gun.
Try different Factory ammo, reloads may be deformed. Bring some of its' used casings along to a Gunsmith, he/she may be able to look at them and see machine marks from how the firing chamber is operating.
I hope my solution is helpful, please rate.
Nov 06, 2012 | Cars & Trucks
What ammunition does this shotgun take? i have 12 gauge shells but it wll only hold 3. whats wrong?
Below is a chart of recommended shot size, gauge, choke and barrel length respectively : 2, 4 12, 16, 20 and Modified or Full and 24" to 32".
Mar 19, 2011 | Sport & Outdoor - Others
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
Have I possibly damaged my Browning 16 gauge Standard weight shotgun Belgium made.by loading/shooting 2 3/4'' shells
Europe loads 2 1/2" and 2 3/4" shells for 16 gauge shotgun as standard and the US only loads 2 3/4" shells. If your shotgun chambers the 2 3/4" shells it should be OK. You can measure the chamber and see if it measures 2 3/4". You can also check your barrel for and bulges in it by looking down the barrel with a bore light shinning down the other end. A bulge should be able to be seen with the eye. If your gun has any bulge, do not fire it again. You will need a new barrel. But It should be OK and I would not expect their to be any bulges.
Nov 14, 2009 | Sport & Outdoor - Others
Goof Luck.
Mar 20, 2009 | Omega Juicers OMEGA GUN LOCK 12 GAUGE...
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Optics Logo
174 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
