Oven cuts out & error code 6 flashes on it
Unfortunately, a part must be purchased and replaced.
https://www.manualslib.com/manual/622772/Candy-Cdi32b.html?page=19
Posted on Apr 27, 2019
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
Posted on Jun 07, 2008
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 18, 2008
SOURCE: Error Code F5 E5
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Posted on Jan 16, 2009
SOURCE: The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Posted on Jan 07, 2010
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
