Authorized Sony service center has worked on problem but could not fix it.
The power board was sent to Sony for repair. Sony found no problem with it. Service center advised Sony was not much help. Model KV-30XBR910. Set is 4 years old.
Horizontal output transformer may be arcing internally
hasnt eaten through or hith voltage anode arcing to crt
well
with the back off of the set,and in a very dark room you
may be able to see a glow or spark from the arc that
corresponds with the pop Also possible to find it by
placing a wooden handled screwdrever on the case of
HOT with yuur ear on the handle and the tip on the
casing (very carefully)no slip downs
Problem doesn't seem to be on the power supply board only! had the service center check the high voltage section already? does the popping sound like the one popcorns make?
I turn on set but won't turn on until I put a hair blower to the back of the set for about 3-4 minutes and it heats up to turn on please help
