Question about Philips Televison & Video
My philips all in one cooker is not showing the time on the screen it’s just flashing lights in a square on risotto setting. Does this mean it’s broken
Posted by Judith Thorp on
2 Related Answers
Anonymous
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
miguel180
Fagor America
  • 4 Answers
SOURCE: pressure cooker not building up pressure
Shanihulugal- please contact us at 1800-207-0806 x 127 or at: [email protected]
We will replace the pressure cooker pot if the unit is defective.
Thank you.
Posted on Jun 08, 2012
Do the low and high settings mean 10 and 20 pounds pressure
It depends on your pressure cooker brand - each one has a different setting. For pressure cookers that reach 15psi (pounds per square inch) the high setting would be 15 and the low setting would be 8 pounds of pressure. For electric pressure cookers the high pressure is generally 12psi the low pressure setting is generally 6 psi.
FYI: No domestic pressure cooker reaches 20 pounds of pressure.
More info about pressure here:
http://www.hippressurecooking.com/pressure-cooker-psi-faq-the-stuff-you-didnt-think-to-ask/
Oct 14, 2015 • Home
Pressure cooker not building up pressure
Thank you.
2answers
Magnavox 37MF321D/37 screen flashes with no pic, power light steady, capacitors in power supply look to be fine
I just fixed a similar problem on mine but the power light was flashing at the same time the screen was flashing. I made a video showing what part and how to replace it. I also added a link to the part I ordered. L5973D STMicroelectronics Mouser
58helpful
6answers
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
22helpful
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
2helpful
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
I need the manual
I too lost my manual and I did an internet search for "wolfgang puck rice cooker" and got to the manufacturers website and printed out the exact manual that came with my cooker originally. i know use the rice cooker at least once a week, love the long grain rice now that i know how to cook it. have tried risotto and am now buying one for my mother for xmas.
Rival 38651-C 6 Quart
once the slow cooker reaches a temperature set point it shuts off. when the internal temperature drops the thermostat turns on again, otherwise even at a low heat, everything inside would boil away. Hence the term "slow cooker."
Televison & Video Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
