Question about The Computers & Internet
Where can I get the factory firmware file for Minix Z64 android please. The file name is minix-z64-20150205.img
Posted by Allan Betts on
5 Related Answers
Damien0410
  • 37 Answers
SOURCE: after upgrade firmware, it is malfunction
reseting the router does not fix firware issues it is a problem with the firmware itself. If it got intoerrupted then you could run into this error and you need to reinstall the firmware. I have a dlink router and they seem to have a problem with some of the firmware distros they deliver. One thing that you can try to do is revert back to an older version that they have if reinstalling the firmware didnt work. If this then does not work then you need to contact dlink.
Posted on Oct 01, 2009
Anonymous
  • 177 Answers
SOURCE: WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
Posted on May 22, 2010
Anonymous
SOURCE: I'm upgrading firmware of the
i know this was from a while ago but 3com 7760's have a problem when uploading it files either firmwere or setting backup files you have to use internet explorer or you will get the "please input address path" error
Posted on Sep 16, 2010
Anonymous
  • 38 Answers
SOURCE: i want a free downloadable
try to download it on this link downloadnew.org/software/minix-m1000/
Posted on Dec 09, 2010
Anonymous
  • 119 Answers
SOURCE: my minix netbook webcam is
This means the driver for the webcam is being uninstalled from your computer. if you have the installation disc that came with the webcam when purchase the you need to insert into your CD-ROM and install the driver. let me know if you have lost the DISC.
Thanks for using Fixya
Posted on May 16, 2011
Minix neo xh8 plus
OK, now, do you have a question?
More and more content that plays on my laptop has no sound or in some instances no images when trying to play on my Minix Neo u1. Is there something I can do?o
download https://www.videolan.org/vlc/download-windows.html if windows is operating system Windows media player has problems with certain file types like AVI right click on file to play and select open with vlc player
How to reinstall aps etc to minix m neu1 tv box
Maybe Youtube has some videoes that address this issue
I go to add source in the box and It won't let me move around the keyboard, driving me nuts. I'm using on a minix
Martin, I'd suggest looking for Minix support on related websites, unless you're sure this is a Laptop hardware problem. Try creating an Ubuntu CD and boot from it to see if the laptop is working as it should.
How factory reset android minix neox8-h
you need to look up the process in google like this http://www.minixforum.com/threads/update-18-okt-2014-x8-h-flashable-zip-for-neo-x8-h.98/ and replace the firmware instead
On my pendo pad THE process android.process.acore has stopped working
Hi you will probaslly have to flash the pendo pad, its not too hard to do here are my instructions, - unfortunatly a pendo pad does not have a recovery menu to access on device boot
note - this solution also unlock the pendo pad and restores it to factory settings even if it wont boot the android os
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back to the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Dec 20, 2012 • Cell Phones
Jade manual model RJDW2470A
Dear Dorothy Minix,
I have potentially found a location for this manual, and here is the link below.
http://appliancejunk.com/forums/index.php?action=downloads
Please do let me know either way if this works or does not. If no, hen I will search again, if yes, then obviously job done.
In the meantime I hope this solves the issue.
Yours sincerely
ouszen
My minix netbook webcam is not functioning??? can u pls help me whats wrong with it? coz the tech said the driver for this webcam is gone! T_T
3helpful
I want a free downloadable driver for my minix m1000 drivers
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
A Kisling
A Kisling
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
