Question about Razor E100 Electric Scooter
Need picture to see how to put front/and rear wheel back on my HCF PACELIGHT 707 XPORT EV RIDER
Posted by Kelly Hicks on
I have a lil' Rider 80-KB2098 it came with 3 rear wheels and 1 front wheel, how do i get another front wheel
Why not contact who you bought it from? Or Google the make/model and see who sells it (including Sears, Target, etc. Contact their parts dept. Contact info for Trademark Games: Trademark Games Inc Company Profile Bloomberg
You tried all of that and what happened? Why would the seller would not rectify the error? You must know who sent or sold it to you. Were you not able to get any contact info from the shipping warehouse? Can't a place that sells them help you? It's not possible to give you assistance when you don't help with better information.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 27, 2017 | Lil' Rider Black 80-Kb901K Fx Wheel...
How can we keep the rear wheel from coming off of the drive shaft?
Lil' Rider Black 80-Kb901K Fx Wheel Repair Questions ...
www.fixya.com/.../p13170224-lil_rider_black_80_kb901k_fx_wheel_b...
Recent Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Blackquestions, ... How can we keep the rear wheel from coming off of the drive shaft?
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike Instructional Video .... Why does the right wheel keep sliding off the tire gear, leaving it free-wheeling? ... WORST piece of trash I've ever triedto assemble! congrats groupon, you ... axle through, this will keep the axle and motor and drive gear fitting tight.
Jan 08, 2016 | Lil' Rider Black 80-Kb901K Fx Wheel...
Whats the rear axle size on a 2009 low rider
Hi Anonymous, check with your local parts department. Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 04, 2013 | Harley Davidson FXDL Dyna Low Rider...
What is front and rear, tire air pressure ,for factory tire and wheel 2003 fat boy
one rider - front tire @ 30 psi, rear tire @ 36 psi
two riders - front tire @ 30 psi, rear tire @ 40 psi.
May 15, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
Rear wheel not centre of frame on harley davidson 09 low rider (dyna) have checked with manual and had to adjust top engine mount, fixed slightly still out by over 10 mm after loosening front and rear...
The easiest way to check rear wheel alignment on a Dyna is by the two little "witness marks" on the rear swing arm. These two marks are just forward of the axle. One on each side of the swingarm. Measure from the mark back to the center of the axle on each side. The distance should be the same with the proper final drive belt tension.
As for the rear wheel being "centered" with the frame, the only way to check that is to take the fuel tank and rear fender off, stretch a string from the center of the steering head along the frame on back across the rear wheel. Simply looking at the way the wheel is positioned in the swingarm may be deceptive. The swingarm may not be symetrical due to the necessity to clear the final drive pulley and such. The engine alignment shouldn't have anything to do with the rear wheel alignment.
For something as serious as wheel alignment within the frame, I'd take the bike to a dealer somewhere and have them check it out. On some bikes, there is supposed to be an offset betweent he front wheel and the rear wheel. Use a piece of straight piece of square aluminum tubing to check wheel alignment.
Nov 02, 2009 | 2003 Harley Davidson FXDL Dyna Low Rider
Are '85 Lowriders wheels 16inches x 3 inches standard?
I believe you bike is an FXSB. The Dyna Low Rider didn't come out until 1993 best as I can remember. The difference is the rubber engine mounts. The FXR low rider had the small rubber front mount and the Dyna low rider has the large front engine mount.
On either bike, the wheels were not the same size front and back. Seems like the rear wheel was an 16" and the front was a 19". A phone call to your local Dealer will get you the answer. Or, you could check out http://www.bikez.com/motorcycles/harley-davidson_fxsb_1340_low_rider_1985.php
Oct 05, 2009 | Harley Davidson FXDL Dyna Low Rider...
How to get rear wheel off yard macine rider
LEAVE MOWER IN GEAR(NOT RUNNING OF COURSE),PUT REAR END UP ON BLOCKS,REMOVE THE CAP,USE BREAKER BAR SET SOCKET ON NUT WITH HANDLE FACING FRONT SUDDEN **** SHOULD MAKE IT BREAK FREE.
May 02, 2009 | Mtd Garden
Tyres and pressures
The Cali' Special tyre pressures:- --------------- 1 RIDER.---------------------- 2 RIDERS Front ...... 2.3 Bar(33.5psi) ................... 2.3Bar(33.5psi) Rear ....... 2.5Bar(36.3psi) .................... 2.9Bar(42psi) I use BT45's on mine but I have the ordinary tubed rims. I find the ride harsh but this may be down to suspension rather than tyres. People recommend running the BT45 at a slightly higher pressure than the book. I got 8500 miles from the front and 4700 from the rear. Although the rear was changed slightly early due to a puncture. I will probably try a different make next time.
Nov 10, 2008 | 2002 Moto Guzzi California 1100 EV Touring
Tyres and pressures
Nov 10, 2008 | 2002 Moto Guzzi California 1100 EV Special...
Razor E100 Electric Scooter Logo
104 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
