Press FN button and then left arrow screen at same time, the screen brightened instantly. Didn't save or do anything else, so was very simple. Problem occurred after updating to Windows 10. So this can work.
No laptop stated at all, just ACER..
Take out the big battery, first.
leave it out
now plug in AC pack. wall AC to PC.
it the screen must show at least errors or text of some kind
if not the PC is dead. (we test the pack with a voltmeter) ask
or get the PC serviced in a shop.
SOURCE: Laptop monitor goes black
it sounds like your display's backlight is going bad. Depending how handy you are, you may be able to replace just the LCD, they might have new or used LCDs on E-Bay.
Alex
SOURCE: at power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
SOURCE: My Acer 22" AL2223W monitor display goes Black
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
SOURCE: My syncmaster 732N powers up okay, goes black in 3 sec
Look for caps with leaking/bulging top or have high ESR (Equivalent Series Resistance, need cap meter with ESR testing).
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Testimonial: "Look like good advice. I'll know after I replace the caps"
SOURCE: Acer Aspire 5536 only gives black screen when i connect power supply
Cable Issues
