Question about Furniture
Wine enthusiast 269 01 92 03. Temperature is set to 66 F and its freezing all my wine. I lost 8 bottles because the wine froze and corks blew. I just bought it in July 2018.
Posted by Karen Klimowski on
Jason Hanks
    New Friend:
  • 17 Answers
This is actually a known problem within the wine cooler manufacturing industry. The thermostat has a bad connection, most likely caused by corrosion due to a manufacturing defect. The wine cooler is reading the temperature incorrectly so it thinks it's too warm inside the cabinet and thus continues to try to cool. Although your temperature might read 66°, if you touch the wine bottles they will feel much colder than 66°. It's a simple change of the thermostat and should be covered by your warranty. However, you need to prevent it from happening again so you need to seal the connection point with a hot glue gun to keep moisture out or else it's going to happen again in another 12 months.
Posted on May 02, 2019
Andrew Taylor
    Top Expert:
  • 34,121 Answers
Still under warranty, contact the seller. The thermostat needs replacing.
It may have been continued.
Amazon com Classic 92 Bottle Single Zone Wine Refrigerator Appliances
WineEnthusiast 269 01 92 03 Instruction Manual Operating Your Wine Cellar...
Posted on Oct 14, 2018
5 Related Answers
Sheldon Dedek
  • 912 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
Anonymous
  • 86 Answers
SOURCE: I have a "the wine enthusiast" wine cooler and
At that temp I'm sorry to say sounds like the compressor is shot or all the gas has leaked out. A service call is about $100.00 to ring the door bell and then add about $500.00-600.00 for a compressor and or 300.00 if the coil is bad. It might be better to get a new box with a warranty. Best of luck!
Posted on Aug 23, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: freezer is working but the
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 30, 2011
ImJustAvg
  • 2006 Answers
SOURCE: The power seems to be OK ,but the wine cooler is
Mcintyre Tv & Appliances
Rr #2, 9622 Dalton Rd.
Grand Bend, ON, N0M 1L0
Phone: 519-238-8270 Appliance Doctor
82 Victoria St E
Wingham, ON, N0G 2W0
Phone: 519 357 4668 Stew'S Rec Vee Service Centre Inc
County Raod 12e G/D
Kippen, ON, N0M 2E0
Phone: 519-263-6058 https://www.danby.com/locator.php?type=dealers It doesn't state if there is in home service or not. But those are the three service locations that are listed in your area.
Posted on Jun 11, 2011
hbsurfdawg
Eric Kirkhuff
  • 95 Answers
SOURCE: Woke up one morning to frozen bottles of wine. The Digital Thermostat still said it was at 8 degrees celcius, but was much colder than that.
Most of these types of wine coolers are not brand names and parts are hard to get. If you paid under $200 for it, buy a new one.
Otherwise you will need to have it repaired by a service station or someone who can get the thermostat and or control board, which is very minimal with these coolers.
You can search for parts if you want to DIY. Search for parts using description and make and model.
Good luck.
Posted on Nov 20, 2011
How to make wine bottle windchimes
17 steps to make wine bottle wind chimes -
1. Gather empty wine bottles, ideally, you're are going to need at least 3 bottles.
2. Remove labels.
3. Wash the bottles.
4. Grab a glass cutter and score around the bottle using a
clamp as your guide.
5. Cut 3 bottles and sand the sharp edges to prevent cuts.
6. Get 3 corks.
7. Acquire 6 3/4 hooks.
8. Buy at least 2 feet (0.6 m) of jewelry chain.
9. Screw the hook on top of the cork.
10. Attach the chain to the hook.
11. Push the cork back on top of the bottle.
12. Repeat steps for the other bottle.
13. For the last or bottom bottle of the chime get a metal earring or any accessory.
14. Attach it to the chain. this will make sounds as the wind blows into your chime.
15. Accessorize the end of the chain if you prefer.
16. Carefully connect all three bottles.
17. Hang somewhere where air passes and listen to relaxing sound it makes!
Mar 12, 2017 | Furniture
How should wine be stored?
There are three crucial elements to consider when storing wine - temperature, humidity and light & vibrations.
Temperature - it is best to store wines between 50-57F
Humidity - try to achieve a level of 60% humidity; which helps to keep the cork moist
Light & Vibration - keep your wines away from direct light and very still so not to disturb the elements inside the bottle
Feb 03, 2013 | Wine & Spirits
Do you have any helpful hints on how to cork a bottle of wine properly?
The most important secret to corking a bottle of wine is to make sure that the corkscrew enters the cork at a straight angle. If it doesn't, it becomes easier for the cork to chip and thereby decreasing the value of your wine.
Jan 10, 2013 | Home
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Jun 08, 2008 | Haier HVF042 Wine Cooler
Furniture Logo
264 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
