Dishwashers Logo
T
Timothy Sprakel Posted on Oct 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung dishwasher heavy and delicate lights blink and cycle stops
Model number is DMT400RHS
ABurns
Level 2:
Habit-Forming:
New Friend:
  • Expert 64 Answers
  • Posted on Dec 22, 2019
ABurns
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
95944
Points
143
A Samsung Dishwasher flashing the Delicate and Heavy light indicates a Heater Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-delicate-and-heavy-light-flashing/
1 Related Answer
dselec10
Shimon David
  • 52 Answers
  • Posted on Dec 21, 2014
SOURCE: I have a Samsung dishwasher dmt400rhs. It stops mid cycle and heating error comes up (. I think its heavy and delicate lights. ) It doesn't drain.
Maybe your heater does not work
thr thermostat will allow the next cycle after water heats
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
1helpful
Dmt400rhs Delicate light flashing. We just moved in and do not know anything regarding machine
It is simple just go to manufactures website and download user manual and follow the user instruction for operation
Samsung dmt400rhs blinking HEAVY light
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Brand new Samsung Dishwasher DW7933LRA Flashing light "HEAVY" and will not start
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
2helpful
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Samsung dishwasher wont run; delicate cycle light blinking
see this causes and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
5( test the main board can be faulty and replace.
7helpful
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
