Question about Philips Magnavox DVD/VCR Dual Player
There has got to be a way
Region 2 dvds
Posted by grizzleee on
Anonymous
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Posted on Aug 04, 2009
4 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: unlock to use Region 2 dvds
No region hack for this player.
Posted on Feb 12, 2008
jaffa012001
L Jefferson
  • 376 Answers
SOURCE: not able to play region 2 dvds
With remote control and player stopped,
press setup, vol+, vol-, vol+, vol-
Use arrow keys to select region 1-6 or 255 for all region.
Numbers appear on TV screen.
Press setup again to save and exit
Try this to make it multiregion. It should work.
Posted on Oct 19, 2008
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: my philips dvp3340 won't play region 2 dvds. is
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_4er6y7
Posted on Feb 27, 2011
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I have bought a Philips
This player can be unlocked, but I'm not 100% certain whether the unlock method works with players sold in North America, i.e locked to Region 1. These players often use different software/firmware which disables the unlock code used for players locked to other regions. Some have an additional chip which prevents them from being unlocked full-stop.
1. Power ON the main unit with no disc inside
. Press the SETUP button (on the top of the player) to open the setup menu
3. Navigate to the PREFERENCES menu using the button below the screen
4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, PREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions.
Please follow these instructions carefully. If it doesn't work the first time, switch the player off then start again at step 1 and try a couple more times. If the current region does not display after step 4, then the player can't be unlocked due to being a Region 1 version.
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
Please try this then let me know if you need further assistance. I'd appreciate it if you could let me know the outcome for future reference. You can reply to me by clicking on "Add a Comment" below your question.
Regards, BElectric
Posted on May 06, 2011
I would like to make it region free because I have a lot of European Dvds, I came from there.
Hello, Marita -
I hope I am correct in thinking you are asking about a DVD player.
If you have a DVD player which is designed for a region other than Europe, Japan, the Middle East, Egypt, South Africa, Greenland (Region 2), it may or may not be able to be reconfigured to play Region 2 DVDs.
Read the information here:
https://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
Depending upon where you reside, you may be able to find and purchase a DVD player which is "region free" and which will play DVDs created for all world regions. See the information here:
http://www.220-electronics.com/region-free-dvd-players.html
Best wishes.
Jul 30, 2018 | Televison & Video
Need to make my dvd player multi region
Region numbers are allocated to DVD Recorders and DVD-Video according
to where they are sold.
The region number of this unit is "2".
The unit will play DVDs marked with labels containing "2" or "ALL".
Dec 06, 2013 | Panasonic DMR-EX773 DVD Player/Recorder -...
Playing DVDs
NoThese days most of the companies are producing Region 0/ALL DVDs If you can get them OR buy a dual region DVD i.e. Region 2/4 which can play on both the regions. Most of the DVDs produced in India are multiregions. Choice is yours now
Apr 17, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Won't play Region 2 PAL dvds
Here is the code..
1. Power on
2. Tray open
3. Push MENU
4. Push 8888
5. Push Display
6. Push in desired region 0-6, (0 is ALL REGION )
7. POWER OFF
8. REGIONFREE!!
Jay
May 20, 2009 | Coby DVD-257
Make dvd player into muilt region so it plays all dvds
hello.go to your setup
there will be a tab that says regions
select region 2 that is multi region it will play regions 1-4
May 11, 2009 | Televison & Video
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
What is a region code 2 dvd player
Most of the DVDs available in India mostly use Region 2, Region 4 and Region 5 codes, all together in one DVD.
Education on region dvd codes:
http://en.wikipedia.org/wiki/DVD_region_code
If you want something on the cheaper side try a Philips DVP5982 Multi-Region DVD Player.
hope that helps!
Jan 31, 2008 | Televison & Video
Dvd player
hope that helps!
Jan 31, 2008 | Panasonic DVD-S52 DVD Player
Philips Magnavox DVD/VCR Dual Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
Do Not Sell My Information Manage Consent
