Computers & Internet Logo
Question about Medion Computers & Internet
Hi Medion S85225 smart plug does not connect to Alexa 9 Echo dot)
When we power on the Medion S85225 smart plug does not connect to Alexa 9 Echo dot).
Posted by Mohan Karnam on
5 Related Answers
knitsterlady
Sandra Wilson
  • 20 Answers
SOURCE: does echo dot work without power connected
You could ask it, lol. Says it's battery powered.
Romeo Direzze
  • 58 Answers
SOURCE: How do i recover login info for echo alexa
To reset your Echo device:
  1. Set Up Your Echo
  2. Set Up Your Echo Dot
Posted on Apr 05, 2017
Paul Bade
  • 1767 Answers
SOURCE: trying to set up Alexa Dot and the instructions found all use a smart phone. don't have smart phone only flip. Can I set up using my Kendal Fire or my lap top & how to setup using one of my devices?
If your Kindle Fire uses Fire OS 3.0 or higher, it should work, provided the Kindle has Wi-Fi capability.
if your laptop has functional Wi-Fi, you can also use your favorite web browser (Safari, Chrome, Firefox, Microsoft Edge, or Internet Explorer (10 or higher)) to set up through Amazon's Alexa page.
http://alexa.amazon.com/
For complete details, see the first section of "Amazon Help: Set Up Your Echo Dot."
Posted on Jul 15, 2017
tech786u
tech you
  • 439 Answers
SOURCE: Setting up my echo.
Call for expert assistance +1(518)348-9393 Thank You
Posted on Jul 16, 2017
john h
  • 28828 Answers
SOURCE: HELP TRYING TO CONNECT MY NEW ALEXA ECHO TO MY WI-FI , CANT MAKE IT WORK . IVE BEEN ON HERE ALL DAY ~PAM TAYLOR 01293523595
notify amazon for assistance
Posted on Jul 24, 2017
3answers
Why is My Amazon Echo Dot Offline?
Read below for many reasons on Amazon Echo dot Offline
Reason1: Loose the power connection between power outlet to Alexa device of cable. The microphone button is On condition if not then press the microphone button is On otherwise Alexa device works as Alexa offline condition or does not respond to the voice commands.
Reason2: If Not updated the Alexa App then Echo dot offline issues show. Then you need to always update the Alexa device with the latest version
Reason3: Wi-Fi signal also causes for Echo device offline, if your wireless signal strength is very high-speed data range then Alexa is working fine otherwise Alexa won't connect to Wi-Fi issues show.
Reason4: Alexa device setting is proper in Alexa App is much important such as Alexa login, wi-fi router connection detail, etc.
2answers
Why Alexa App Say Alexa Device Offline
Alexa device goes offline is not alert, but it shows not respond and then Alexa App say as "Alexa device Offline"
Now, you need how to fix the Alexa device's offline issue?
Learn to follow some instruction steps for solve Alexa Device offline.
You can check your Alexa device is in working condition.
All wire and device connections are in working condition and correct connecting in manner.
Wireless networking working active state.
Alexa device kept in Wireless network range and connection of Alexa device and wireless router through the same wireless network.
Use the same user ID registration on the Alexa device and Alexa App during Alexa Setup.
Alexa App is updated latest version.
Sometimes offline Alexa errors also occur due to dust particles on the Alexa device then you can need to clean the Alexa device in your daily routine.
If you have more information and Help then contact Alexa helpline today.
2helpful
4answers
Why Does My Alexa Echo Appear Offline? How to fix the Alexa Offline Problem?
Here Some following important Step to Solve this issues
First you need to restart the Alexa Device.
Check your Power plug connection between Echo and main Switch power. make sure your Power cable is working.
Check your Alexa App on your Smartphone to make sure it is Updated conditions.
Alexa makes sure it is not faulty conditions.
Alexa is kept in wi-fi range.
Wireless router is working and must be connected with the Alexa Echo device through the same network.
Now, you can check Alexa offline to Alexa online and working mode.
If Echo dot offline is still a problem then contact Alexa Helpline Expert today they will resolve this problem at a time.
3answers
How do I connect my Fire Stick to Alexa Dot
Connect your Alexa to Wi-Fi - Setup Alexa Dot
Ad·https://www.alexiaassignment.com/
Having issue with Echo Setup on Wi-Fi, Get Expert Guidance, Complete Alexa Set Up Guide
Step by Step Manual Help - Download the Smart Alexa Setup
Ad·https://www.mybiowriter.com/echo-app
Setup your new Device with easy instructions. Connect with Alexa Skill to use smart lights
Echo Dot Plus App Setup - Download latest App now
Ad·https://www.nextgenhomesolutions.us/
Step by step procedure to Setup your Echo Dot plus device. Get your device online now. 4:26 And registered with the same Amazon. Account open the alexa app on your phone and tap on the threeMore
How to Control your Fire TV Stick with Amazon Echo Dot ...
I have a atomi smart plug and works with amazon Alexa. Can I use amazon echoe dot
Yes, Amazon Echo Dots are Alexa compatible, so you may use the Amazon Echo Dot for your Alexa compatible smart plug.
7answers
Setting up echo dot
hi roger.
see if this helps you out.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
or if you need more help go to this link.
Setting up echo dot Google Search
1helpful
5answers
How do i setup my amazon alaxa echo dot
There are Many People in the 21st Century are Wanting Some Difference Things Who Change their Life. The Amazon Echo Dot is one of those things Who Change the Human Life through the Voice Search. It is the Product of Amazon that is Coming in the Market to Make the Human Life Perfect. Amazon Echo Dot is a Speaker that is Used in Amazon Alexa. After Purchasing the Echo Dot, Many Peoples are Doesn't Know to Setup Amazon Alexa so For It You Have to Visit Our Official Website.
Top Medion Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
