The manual states no changes needed until over 5000ft. If needed take to honda service center for modification... blah, blah, blah. Not sure what "modification" they do other than replace the limited adjust (thanks "CARB") air fuel with adjustable, but as memory serves it's not that simple... if you break away the limited adjust the needle wont stay where set (thanks again "CARB").
Probably the easiest and least expensive for a DIY is order an adjustable replacement carburetor off ebay (~$15 US delivered).
Due to the low air pressure in the plateau region, the air is thin and the oxygen content is small. Especially for naturally aspirated diesel generator sets, the combustion conditions are deteriorated due to insufficient intake air, so that the diesel generator set cannot emit the original specified calibration power even. The basic structure of diesel generator sets is the same, but the diesel generator sets have different calibration powers, so their ability to work in the plateau is different. The following are the considerations for the use of diesel generator sets in the highlands.
https://www.dieselgeneratortech.com/generator-sets/Guides-to-Use-Diesel-Generator-Set-In-Plateau-Areas-and-High-Altitude.html
The reduced atmospheric pressure at high altitude means the standard carburettor settings will not allow sufficient fuel to flow for efficient running.
The dealer or manufacturer should be able to provide details of alternative settings - the jet sizes are usually increased a few points for every 5000 ft above sea level.
The cooler temperatures experienced at high altitude would probably change the engine oil specification to a lighter or thinner grade.
SOURCE: good 2500w generator and my r/v Dometic 13,500 a/c.
The 2500w gen. is good for approxiamtly 20a. so, you have to look at the initial draw on start up of a\c, ur 13.5k unit will pull around 10amps under load. Refridge, pulls probably 10a. so, there's the math of it. Check around on my figures, I'm not always right, but, I come close enough to it.
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
SOURCE: Getting error code 13 when heater runs 2-3
Hi and welcome to FixYa, I am Kelly Oxygen Depletion Sensor (Poor or Improper
The error code 13 from memory is indicating a venting / flame / improper combustion problem. I recall seeing a C7 or a C4 before an error 13 though.
There is one sensor called the Oxygen depletion sensor and the code 13 appears for this sensor when it is sensing poor or incomplete combustion
Combustion)
I honesly am not certain but I think it is item 4 of the parts list below (Flame rod) PN: RTG20164H
^- I believe this is the sensor causing your problem This is a stand alone sensor.
Your other 4 sensors.
PN: RTG20164P (Yellow) Heat exchanger Thermisor
PN: RTG20164R (Blue) Ambient Air Thermistor
PN: RT20006AR (White) Inlet Thermistor / water line
PN: RTG2006BB (Black) Outlet thermistor / water line
The inlet and outlet thermistors will have the same resistance Pair 1
The heat exchanger and Ambient Air thermistors will have the same resistance. Pair 2
It is best to check these when the unit is at Ambient air temp as the resistance values will be the same. If you note any major resistance differences or opens..between each of the thermistor pairs, the thermistor is bad.
Your parts are in this link pages 14 - 16:
http://waterheatertimer.org/pdf/Rheem-TanklessParts-Accessories.pdf
These thermistors if they outright fail show up as error codes 29, 31, 33, 34 and 35 You could just have dirty / corroded thermistor terminal(s) connector(s) or minor corrosion on the main PCB.
Just make sure your repair efforts are directed toward the flame rod and associated wiring.
Thanks for choosing FixYa,
Kelly
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
Fig. Fig. 49: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission
Fig. Fig. 50: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 51: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission
Fig. Fig. 52: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Fig. Fig. 53: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with manual transmission
Fig. Fig. 54: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with manual transmission alternate
Fig. Fig. 55: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission
Fig. Fig. 56: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission alternate
Fig. Fig. 57: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission alternate
Fig. Fig. 58: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 59: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Fig. Fig. 60: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 61: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
