Baking Logo
p
peter giles Posted on Oct 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When my wife cooks spong cake it does not rise
  • Mary Santos
    Mary Santos Mar 06, 2019
    If there is any trace of greasy substance it will fall. Make sure that the bowls are grease free. Also, once beaten, it cannot sit around. So you must prepare the pan ahead of time so that you can pour the batter immediately into the pan and then into the oven. Sponge cakes are delicate so now vibrations around the oven either.
  • Baz Hawkeye Jun 01, 2019
    So right. It goes for meringues too. Always scald the mixing bowl and whisk with boiling water before use for sponges etc. Then invert the bowl on a grease free cloth and let it dry naturally. If you wipe it with the tea towel, you’ll contaminate it.
Baz Hawkeye
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jun 01, 2019
Baz Hawkeye
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
14312
Points
57
A traditional egg sponge uses only plain cake flour, caster sugar and fresh hens eggs. Nothing more or less. The method requires grease free utensils and skill. Whip the eggs to a soft peak with the sugar, adding a about a quarter of the sugar at a time. When fully whipped, treat gently or you will knock the air out. Gently fold the flour into the egg/sugar mix until just cleared, don't over do it. Gently pour the batter into the prepared cake tin(s) and let it settle of its own accord. The tins should be greased and then a small amount of flour shaken around then to cover the grease. Knock out the remaining flour. Bake straight away at 400 degrees F for about 20 minutes. Test by gently pressing on top. If it springs back, it's done!
Carissa Johnson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Nov 08, 2018
Carissa Johnson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
0
Helped
6372
Points
64
If you bump in the kitchen and move around too much the cake will fall. If you open the oven too much it will fall also. Try using less sugar.
Kami
Level 2:
Novelist:
  • Expert 307 Answers
  • Posted on Oct 20, 2018
Kami
Expert
Level 2:
Novelist:
Answers
307
Questions
0
Helped
155761
Points
375
The best sponge cakes in my experience use both baking powder and folded in, whipped egg whites as leavening. Sifted cake flour, instead of all-purpose, will also lighten them quite a bit. Baking powder can go stale, so always check the date before using.
Helena Barclay
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Oct 19, 2018
Helena Barclay
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
533
Points
7
There are a lot of factors. It would be helpful to see the recipe.
You could be using the wrong amount of baking powder, or nun at all
Are you using self rising flour
Your oven may be the wrong temperature.
2 Related Answers
Anonymous
  • 833 Answers
  • Posted on Nov 21, 2008
SOURCE: un even cooking model #790.92314301
Generally, most units are properly calibrated at the factory.  Get an oven thermometer for a few dollars at Ace and place it in the oven and run it at a particular temperature...say 350.  If the thermometer is off more than about 15 degrees after warm up and stabilization...another 10 minutes, most manuals have a way of altering the thermostat settings to compensate.
Anonymous
  • 187 Answers
  • Posted on Apr 27, 2010
SOURCE: when I cook my Victoria sponge cake it does not rise is my oven
Well, your temp seems about right, but you may need to experiment. A good thermometer helps in gauging temp, ovens are notoriously inaccurate. All oven are different, but it is usually recommended to go down 25 (15C) degrees from the recipe if you use convection. The type of pan you use has an effect. Glass needs to be 25 degrees less, and nonstick/dark pans brown faster than the insulated type. Make sure that you fully preheat as well, or the bottom may burn. Other than that, convection cook times are less if the bake time exceeds 15 or 20 minutes. Thanks for your question, sorry I can't give a more precise recommendation.
Why don't cakes rise?
Taras, Check the attached links,instruction and guides on cake baking strategies. Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.instantanswer.org/why-did-my-cake-not-rise_608.html
Reasons for Cakes Not to Rise LIVESTRONG COM
http://www.mumsnet.com/Talk/food_and_recipes/895729-Why-don-39-t-my-cakes-rise
Why Don My Cakes Rise High Enough
2answers
Which is the best jellyroll pan for sponge cakes?
You can try Chicago metallic commercial jelly roll pans, they are perfect for making sponge cakes and much more.
Jul 29, 2015 • Home
4answers
I have G273v samsung microwave. can i bake a cake in that
Yeast will not rise using conventional microwave oven type energy. So, you can't have your microwave and eat it too ... (groan - sorry)
1helpful
Does self rising flour need time to rise/
self rising flour uses baking powder as a leveling agent, so it rises as it is being heated in the cooking process, not like a yeast dough.
the following is taken from another site, I could not have said it any better.
Self-rising flour has an almost magical sound to it. And if you look at recipes that call for it, you'll see that they do not call for the addition of salt or leavening agents, though biscuits, cakes and breads made with seem to rise up just fine. The reason for this is that self-rising flour is actually nothing of the sort. It is flour that has a leavening agent - baking powder - and salt added to it during packaging. Since the ingredients are evenly distributed throughout the flour, you will get the same nice lift to your baked goods every time you use it. If you don't have self-rising flour and you have a recipe that calls for it, you can make your own by combining 1 cup all purpose flour with 1 tsp baking powder and 1/4 tsp salt. Similarly, if you only have self-rising flour, you can reduce the baking powder and salt called for in a recipe that uses standard all purpose flour.
Now that being said, it is also worth noting that there are several brands of self-rising flour that have a lower protein content than all purpose flour (11% protein). They are effectively cake flours (8% protein). Wheat protein, or gluten, is what gives baked goods much of their structure, but it can also cause a bread to be too dense or tough. White Lily and Presto are two examples of self-rising brands that use a low-protein cake flour as their base, and if a recipe calls for one of them, you should use cake flour in place of all purpose in the conversion given above.
Jan 03, 2015 • Home
Cupcakes not rising when using cake mixes
It's possible that it's out of date and lost its leavening 'power'. Check the box directions to make sure your mix can be used for cupcakes. Also, not adding enough liquid might be the problem.
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
when i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
Hi my daughter got the Disney Princess Magic Rise Oven for Christmas and unfortunatley we have misplaced the instructions on how to get the cakes to rise, can anyone tell us, or point us in the direction...
just squeeze the air out of the cake, position the circle on the bottom of the cake onto the circle in the oven, wave the wand over the heart or press the heart and it should rise in 5-30 seconds
2answers
What should fridge temp be for cakes and cooked meats?
the ideal temp in a fridge is +5C,no colder,or your veg will spoil.
When I cook my Victoria sponge cake it does not rise is my oven
2answers
Can the oven be used DRY or do you need to have water in it always? If so how do you cook a cake?
When you bake a cake the water is in the batter. The baking powder gives it a fizz, and the egg helps hold it in place once it rises.
Top Baking Experts
Don A
Don A
Rick Rock
Rick Rock
Are you a Baking Expert? Answer questions, earn points and help others
