Wont start
Led Samsung 40 five-time blink but led not on
Posted on Apr 06, 2019
Turn the screw gently clockwise until it won't go in any more. Then turn it anti (counter) clockwise 1 complete turn. That should enable it to start but you will probably need to adjust it when the engine is warm. Failure to start can be because of a range of causes so I suggest you check the basics first like ensuring the fuel is fresh, that there is spark at the plug and that the choke is turned on if the engine is cold.
SOURCE: starts ok wont pick up speed
check to see if the throttle cable is hooked up to the carb. look at the back of the motor and watch as you pull the the throttle to see if the cable is hooked up. if the cable looks to be working correctly then pull the spark plug up and heat it up with a blow torch and put it back in. if the motor runs good then you need a new spark plug. if those two things do not work then you need to replace the carb diapram and gaskets.
hatter1
Posted on May 19, 2009
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
SOURCE: how to start the Stihl BR 320 leaf blower
PRIM IT 3 PUMPS PUT ON FULL CHOCK PULL IT TILL IT TRYES TO START THEN MOVE THE CHOK TO HALF AND IT SHOULD START LET RUN FOR A MINN AND TAKE OFF CHOK
Posted on Sep 30, 2009
SOURCE: my stihl fs 350 wont start at all any sugestions
I would have a shop do a compression test on the engine. It should be at least 100 psi to run. And then a spark test on the ignition module to see if it firing to the spark plug. I would look at a carburetor rebuild. I would also mix up some fresh fuel mixture; anything over 30 days now is considered bad gas.
Testimonial: "thanks for the info i will try these and see what happens, thanks again,mark"
SOURCE: Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
Posted on May 08, 2010
Jul 17, 2017 | ATVs
Apr 11, 2017 | Kia Cars & Trucks
Feb 09, 2014 | Stihl Garden
Feb 01, 2014 | Stihl Garden
Jan 22, 2014 | Stihl Garden
Apr 15, 2013 | Stihl Garden
Jun 27, 2010 | Garden
Oct 11, 2009 | Oregon Scientific Complete Carburetor for...
Jul 08, 2009 | Garden
May 08, 2018 | Stihl Saws
387 people viewed this question
