SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Testimonial: "This worked perfectly! Thanks!"
SOURCE: I need to pair by Jabra VBT3050 with a different
long press the side key until the light keep blinking;
same time u search it with ur mobile phone then pair it with code 0000
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
SOURCE: Just purchased Jabra Cruiser 2.
Try to reset and pair it.To reset follow below instruction
Thank You
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
