Question about Summit Refrigerators
What is the right temperature setting on a summit fridge
Posted by Frank Gonzalez on
Lawrence Oravetz
  • Summit Master
  • 10,543 Answers
The right setting depends on how many door openings the fridge sees in a day and how packed with food it is. If the fridge is warm, try increasing the thermostat slightly to a higher number. Come back 24 hrs later to see if it has gotten better, You may need to do this a few times. If you don't get any results, then it's possible the thermostat is faulty or the fridge has a leak in the cooling system.
Posted on Oct 13, 2018
What are the remote codes for a Summit Broadband DTA digital adapter remote to operate a TCL 26" HDTV?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jun 01, 2015 | HCDZ General Remote Replacement Control...
Refrigerator not gettting cold enough
check too see if the temperature to your fridge is set to the right temperature. Maybe you have to get the fridge colder.
Apr 20, 2014 | Candy CPL321K Refrigerator
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    My Summit FF560L refrigerator is not cooling- it is only one year old
    There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
    Refrigerator2_bing.gif not Cooling or Fridge not Cooling
    http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
    How to Defrost Refrigerator Defrost Timer Problem
    http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
    heatman101
    Jul 12, 2010 | Summit Commercial Refrigerators
    Temperature setting
    The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
    Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
    Freezing all veggs in fridge
    The temperature in the fridge should be from 32-40 degrees. Go buy a little fridge thermometer and place it in there. They are cheap and you can pick one up many places. I leave mine in year round. Then adjust your settings accordingly. Don't do anything drastic adjust, then check in twenty-four hours then readjust if necessary to reach the proper temperature. No visible frost inside the unit anywhere right?
    May 21, 2009 | Amana ATB2135HR Top Freezer Refrigerator
    K-Mart Homemaker brand, 40 bottle wine cooler fridge
    Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
    Jun 10, 2008 | Refrigerators
    Refrigerators Logo
    360 people viewed this question
    Top Summit Refrigerators Experts
    ray gallant
    Tom Chichester
    David Spradling
    David Spradling
    Are you a Summit Refrigerator Expert? Answer questions, earn points and help others
