Question about Hitachi Televison & Video
Hitachi LE55A6R9A power light comes on.. nothing else happens?
Posted by Michael Lower on
Hitachi LE55A6R9 / LE55A6R9A need a back-light inverter, Which one do I have to order?
Contact the authorized service center for Hitachi, to get more details.
Hitachi LE55A6R9A audio no picture(can hold light near screen and see picture)
Test LED output voltage, if its missing look at the power board as being bad, also test the PWM voltage and make sure its between 2 and 4 volts, if its not correct the main board may be bad.
I own a hitachi tv model le55a6r9a which has no pic but when using flashlight trick I see the picture can someone tell me what would need fixed with a part number
Your issue is in the LED lamps or power supply, test the voltage at the connector that comes out of the power board and see if you have voltage there of 100 plus volts DC, if you don't unhook the connector and see if you have around 150, if you do then you have at least one lamp that is bad and needs replacing, if there isn't any voltage there its the power board
Hitachi le55a6r9a has audio but no picture. When you shine a flashlight on the scree, you can see a dark image. Which piece needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Hitachi TV 55inch LE55A6R9A doesn't have picture or audio but has power.
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
My Hitachi America,Ltd. Model-LE55A6R9A has a black screen volume but no picture comes on like it works help
Televison & Video Logo
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
