Question about Firearms
The sight on my Sig MC CO2 air rifle has the pellet hitting well below the target. What adjustment can I make? Thanks.
Posted by Cliff Ehrlich on
5 Related Answers
Anonymous
SOURCE: Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Posted on May 18, 2008
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: I need a manual for a crossman Model 160 pellet rifle
Here is a link to the entire Crosman manual. Scroll down the page to the 160 model and download the owner's manual free.
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Posted on Aug 29, 2009
Testimonial: "This was a termendious help. Thank uou very much Charles"
Mustgo
Vincent G
  • 2363 Answers
SOURCE: co2 cylinder stuck in reciever
Back the screw/knob out and use a strong magnet to pull the cylinder out.
Posted on Mar 04, 2011
Patrick Fuller
  • 3 Answers
SOURCE: how to sight in crosman
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
Posted on May 05, 2011
cwradio73
  • 1162 Answers
SOURCE: I need to replace the front(muzzle) sight on my Daisy Powerline 1000 pellet rifle, is this possible?
yes they carry parts for your gun. contact daisy, or crosman. their site has links to each other.
Posted on Jul 26, 2017
How to adjust sights on the AK 47
Take it to your local county sheriff, they know how to handle Kalashnikov rifles.
Oct 19, 2018 | Firearms
How do I put the co2 cartridge in my power line daisy426?
What type of air gun is this? hand gun, rifle what?
Oct 14, 2018 | Firearms
How to aim on a shotgun for still targets at 20 yard with shot 4 steel shot
What is the type of choke you are using? You want a FULL choke for the tightest pattern. Then you need to "pattern" your shotgun. Put a large piece of cardboard (4' x 4') on a range backstop at 20 yards and place a highly visible 3 inch orange dot or simply draw a 3 inch letter x in the middle of the cardboard. Take a string, 36 inches long and staple it to the center of the dot or X then tie a pencil on the other end. Stretch the string out and draw a perfect circle on the cardboard 36 inches from the center, then remove the string and pencil. From a shooting bench, use a shooting rest to steady your aim. Shoot at the center dot or X by pointing the shotguns bead sight directly at the dot or x
Look at the pattern of holes the shot pellets made. If they are mostly centered within the 36 inch circle, your hold would be right on the target. If they would, say, be up from center, the hold would be below the target. Up and to the right, the hold would be down and to the left, etc.
A gunsmith can correct this and make the gun shoot so that your hold would be on the target instead of trying to compensate for the barrel characteristics of your shotgun.
Sep 13, 2018 | Firearms
What are the most expensive rifle scopes?
Nightforce, Leupold and Schmidt-Bender Scope will get up there in the price point. Schmidt-Bender glass especially will be quite expensive. Their high end glass can easily exceed $10,000.
Jun 04, 2018 | Firearms
"why won't my benjamin regal np air rifle won't discharge a pellet
Could it be that the barrel needs cleaning, is it blocked or it could even be bent if it has been dropped, you wouldn't see this with the ***** eye but a good gunshop should be able to define the barrel as true.
Jun 03, 2018 | Firearms
Do I need fully multi coated Spotting scope or Rifle scope?
Scopes with fully multi-coated internal glass-to-air surfaces (lenses) are recommended as they allow the highest level of light transmission through the binoculars (90 - 95% of the light that enters the binoculars will reach the eye) with limited internal light scattering and reflectivity. This results in fully multi-coated binoculars, spotting scopes and rifle scopes producing brighter, sharper and higher contrast images than coated or multi-coated binoculars. Unfortunately, fully multi-coated optics are more expensive to manufacture and are often only incorporated into higher-end binoculars, so your choice may depend on budget.
Mar 22, 2018 | Firearms
Firearms Logo
258 people viewed this question
Top Firearms Experts
Marvin
Marvin
jws1013
john h
Are you a Firearm Expert? Answer questions, earn points and help others
